Sponsored by:
Sponsored by: CARiD
Idle
Old Dec 13, 2004 | 06:56 PM
ftltmp's Avatar
Question Idle
Can someone give me an idea at what temp their truck would idle up to 1000rpms? I have yet to see mine idle up.Thanks
Old Dec 13, 2004 | 07:26 PM
apache's Avatar
??? temp rise at 1000 rpms? Better there than at 850 for long periods, but still wont get to full temp most likely.
Old Dec 13, 2004 | 07:32 PM
ftltmp's Avatar
What I am talking about is when it is cold outside our truck is supposed to idle up to 1000 rpms to warm up, how cold does it have to be to idle up? Mine has yet to idle up.
Old Dec 13, 2004 | 09:08 PM
amartinson's Avatar
I had that option reflashed and enabled on my truck recently. So IF the new ones are the same, it ramps up to 1200 rpm idling, after about a minute, when the intake temps are below 32 degrees and goes into the three cylinder idle when intake temps are below 15 degrees. Works great!
Old Dec 13, 2004 | 09:42 PM
HorseHauler's Avatar
yesterday morning i went out and started my truck, came back in for a couple mins and when i came out it was ideling at 1000 rpm. it was about 34*F out... also my truck wasn't plugged in all night... its a factory item on the 03's i know, dont need a flash... not sure about the 04, im pretty sure its the same except u get a choice to go and get the cruise control high idle enabled by the dealer...
Old Dec 14, 2004 | 05:53 AM
amartinson's Avatar
Since it reads coolant temperature, mine also does not activate when it has been plugged in for a couple of hours.
Old Dec 14, 2004 | 10:40 AM
Journier's Avatar
hmm its 26 degree's out by me right now... as soon the truck started today it went straight to 1000 rpms
this is an 04.5.... hmmm?
do i need the flash for a faster idle or do i have the standard idle up?
Old Dec 14, 2004 | 10:55 AM
mudpup221's Avatar
Journier,
Your truck is doing what it is supposedto do. If all the parameters are met (usally outside temps being below about 32 degrees) it will automatically idlew up to 1000 rpm's shortly after start up when ideling in park or neutral. This feature is programmed into all trucks from the factory and requires no flash or enabling.
This is seperate, however, than the user controlled high idle feature that you can control using the cruise control buttons. This feature must be enabled by the dealer. I had a difficult time getting my dealer to enable this (they didn't know about it). I finally got them to figure it out and I really like it. If you have this feature enabled you can manually control the idle speed anywhere between 1100 rpm and 1500 rpm. It will stay where you set it for as long as you want as long as the truck is in park or neautral and you don't touch the service brake or turn the cruise off.
Old Dec 14, 2004 | 11:07 AM
amartinson's Avatar
Yours is working correctly. It is the second gen's that have/can get the feature to idle at 1200 rpm.
Old Dec 14, 2004 | 06:20 PM
Journier's Avatar
ok thanks for the info guys,
this thread helped me out atliest
Old Dec 14, 2004 | 07:54 PM
this morning i started my truck and it went straight to 1000 instead of waiting a couple of mins.... it was about 20 degrees out.
Old Dec 14, 2004 | 08:41 PM
AaronT's Avatar
Before I had the TSB done the high idle would come on immediately which was wrong. After flash, and grids have cycled, and 180 seconds the idle slowly ramps up to 1000.
Ram1999
Feb 11, 2007 10:49 AM
pet05
Oct 5, 2006 11:02 AM
rdc
26
Jul 31, 2006 09:17 AM
dieselnewbie
Jan 18, 2005 10:48 PM
steelsoldiers
21
Dec 19, 2002 04:08 PM
