Sponsored by:
Sponsored by: CARiD
Hooked!!!!!!!!!!
Old Nov 24, 2004 | 07:16 AM
xp8103's Avatar
Talking Hooked!!!!!!!!!!
Man..... If I wasn't hooked before I sure the heck am now......
My wife and I picked up our popup at the dealer last night (it was being serviced). It's a 2003.5 Coleman Utah, the largest PU unit Coleman makes with a 12' box. It's not terribly heavy (3600 gvw or so) but I always knew it was behind my Expedition. There was no way I could haul it with both OD on and cruise on unless I was on perfectly flat level ground or going down hill. Last night we hauled it home, OD on and cruise set to 65 and the Silver Ghost barely broke a sweat!!!
Old Nov 24, 2004 | 10:37 AM
kandgo's Avatar
Condgradulations on the new to you truck, Guess what it will do the same with a 5th wheel behind it,, so if you do not want to go the expense do not let your wife know it's full capability's. , My wife tends to think the stronger I make my truck pull and run the bigger 5th wheel trailer she can get???? Goodluck and Happy camping...Rick
Old Nov 24, 2004 | 12:45 PM
xp8103's Avatar
That brings up the question. Most of what I had heard and read about my Expedition said NOT to tow in OD. And as I said above, I couldn't use cruise very often.
Are there any sorts of prohibitions when hauling with the CTD?
Old Nov 24, 2004 | 01:03 PM
BigBlue's Avatar
Below 55mph, turn OD off. Above it, leave it on. That's about it. I love these trucks.
Old Nov 24, 2004 | 01:10 PM
xp8103's Avatar
I would have figured that. I pulled away from the toll with OD off and couldn't go much above 50 or so without revving over 2k.
Fair enough. Thanks!!
Old Nov 24, 2004 | 01:15 PM
RustyJC's Avatar
Yeah, look what my wife did to me (see signature)!
Rusty
Old Nov 24, 2004 | 08:06 PM
welder27's Avatar
Revving above 2K isn't bad. In fact, the CTD gets the best mileage somewhere around 2000-2300 RPM's w/ a moderate load of 10,000 lbs. Those RPM's also depend on what kinda gearing you have in the rear axle. If you don't wind up the RPM's w/ a turbo diesel the unburned fuel turns into carbon deposits that build up on the valves and pistons and makes your truck a little less spunky over time. You also lose fuel mileage. Sometimes you can't avoid it. A lot of regular unloaded driving around town and on the highways doesn't allow your engine get hot enough to burn off the carbon. The cure: Find something heavy and haul it for about 200-400 miles up mountains. It sounds crazy, but it works! Think of it this way...the CTD is the powerlifter of light duty truck engines...and just like a powerlifter, if they don't workout, they lose their strength.
MasseyMan1089
Competition / Pulls / OffRoad
16
Jul 31, 2005 12:57 PM
shoe
Apr 2, 2005 07:51 PM
03CTDCO
Feb 27, 2005 07:30 PM
0
May 2, 2003 10:07 PM
Copenhagenjunkie
Dec 27, 2002 05:45 PM
