home made aux tank
home made aux tank
Any one every made their own aux tank? What requirements are needed. Does a diesel tank have different specifications than a gasoline tank? I want one to bascially double as the floor for the bed. So maybe a 6' by 4' by 12" high.
I have one that sits where the spare used to sit under neath. I think it holds 40 gallons plus, not sure never filled it. it has a valve and a transfer pump that just fills the regular tank (connected to the filler) the switch doesn't work so I haven't messed with it. I think a 2-3" in tank the size of the entire bed would be pretty awesome! Hold a lot of fuel and would put traction weight on the rear axle! Sounds cool I say go for it! I am not sure of what metals would be best. bare steel would rust over time (inside), but galv might react with fuel. Aluminum might work so would stainless.
Thats my .02!
Thats my .02!
I had one built for my '98 out of 3/16" aluminum and holds 51 imp gal or 58 US gal. I haven't installed it in my '07 yet - just eyeballing says it isn't going to fit, but I have to get out the tape measure to confirm.
The place that built it for me will not build one out of 1/8" aluminum as they say too many have cracked - 3/16" is the minimum.
The other reason I have yet to install, is figuring something with a toolbox combo to work with a GN hitch on a Mega. Everything points to having something custom built again.
I quickly did the caculations for a 6 x 4 x 1' tank and they turn out to be rougly 180 US gallons. Just the weight of the fuel that would be about 1314 pounds not including the weight of the material for the tank itself.
L x W x D = cu ft.
cu ft x 7.47 = US gallons
#2 is rougly 7.3 lbs a gallon.
HTH's
L x W x D = cu ft.
HTH's
L x W x D = cu ft.
HTH's
L x W x D = cu ft.
HTH's
I built mine from 14 ga galvanized because I couldn't buy one that would fit under my toolboxes. Bent it up on a 10 foot brake and welded it with fluxcore wire after scuffing all the edges. Then I pressure tested it at 4psi with soap and water to check for leaks. It has a bevel in it so I can see my gooseneck ball for hooking up and I run through 55 gallons a day. No problems at all for 3 years and counting.
Could get intresting while driving on wet or icy roads.
Jim
PRO-NRA
16
04-01-2008 12:13 PM
groran
03-19-2007 07:44 PM
