help, need an Allis Chalmers mechanic
specifically their 6000 engine from about 1958. I have one that barely runs, blowing white smoke. figured it was a headgasket. got it halfway tore apart and found two bent pushrods. coolant was just changed and came out of the head perfectly green, if the head gasket failed wouldn't it be contaminated with oil? also wondering if the injectors need to come out to pull the head. thanks.
haven't gotten the head off yet.
Sumtimes you can remove the exhaust manifold and see if you can get alook at the valve stems. The steam cleans the carbon up some times,....I'm not an A/C mechanic but thats where I'd start looking
Aha...the 6000 engine wasn't one used in tractors...only industrial engines
Either way, if you found bent pushrods, I doubt it was the head gasket. Were both bent pushrods on the same cylinder?
Chris
Chris
yup #2 cylinder.
It wasn't used in Ag machinery...only industrial AND construction engines.
You really won't know anything until you pull the head...my guess is there will be valve marks on #2, or some bent valves. As to what caused it, could be a bearing going bad, could be a broken valve, or many other things!
You should find it soon enough...I'd say it will be obvious. I'm not as familiar with the industrial engines as the Ag engines...but they should all be somewhat the same.
Chris
Chris
Each and every time you start it does it spin like a top and bust off running or does the starter have to grunt hard as it starts to spin,...particularly on the first or second revolution then spins like a top? Is it attempting to hydraulic lock?
never started easily, it's 50 years old, takes a shot of ether or two.
If it's been a year sense it's run and you can still rotate the thing lately then disregard all my blabbering LOL(no water leaking into the cyl's)
White smoke still got me Baffeled though.....
Anyhow
Anyhow
Just because the gasket blows, doesn't mean that oil will get into the coolant. depends on WHERE the gasket blew. I'm with the rod bearing too! That is more than likely why the pushrods are bent. Have a buddy who is into the AC's pretty heavy. Remember him talking about doing rods and mains quite often on those. I'd yank the head to be sure, but I'll bet you have more than one problem.
jimbo486
Sep 25, 2011 09:51 AM
