Edge hot comp
Edge hot comp
I have a bone stock 99 24 valve. A friend of mine is selling me a "like new" edge hot Comp. I am wanting opinions on what other performance mods I should put on my truck to make this operate safely so I do t burn up my vp44. I have a air dog 150 pump I just need to buy the fitting get for the vp pump. But other than a upgraded fuel system is there any recommendations on steps I should take?
Whenever you are adding fuel/power you should look into a good set of gauges with boost and pyro at a minimum. Depending on how much power you are adding fuel pressure and drive pressure would also be worthwhile.
Also, Welcome to the forum, you should go to the user cp tab at the top left and fill out your signature so guys can see what you have and will be able to offer much better advice.
lvmknsmoke..
08-13-2009 10:59 PM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
