engine oil questions
I use the 0w40 ROT T in my quad during the winter.
I wouldn't use the stuff in my truck unless it was -40 all the time.
There are alot of good lubes out there, biggest thing is to change the oil on a regualr basis and don't forget to use a good filter or it will all be in vein when the filter falls apart..
Fleetguard for me..
Jason
Fleetguard for me..
Jason
Originally posted by Dr. Evil
Why?? Its 0W40
Why?? Its 0W40
You're much better off using a 15w40 unless you live in the artic.
Originally posted by infidel
It's a well proven fact that an oil with a viscosity spread of over 25 points breaks down on the high end much faster. In other words your 0w40 will end up becoming a 0w25 before you want it to.
Either way...it takes a lot more V.I. (Viscosity Improver) to spread the numbers so far apart....so you end up with less base oil/additives...unless someone figured out how to get more than 32 oz. in a quart? So you still end up with an oil that doesn't last as long or protect as well.
As Infidel said....better and longer protection if you stay within 25 point spread.
RJ
...it is a Group IV synthetic meaning that it is 100% synthetic (which makes it virtually the same as Mobile 1...
The fact that it now contains Group III, to help hold down costs, comes from a Mobil employee. The reports from racers are all hear-say....as I have never tested or used the newer Mobil I!
RJ
Originally posted by rjohnson
FYI - Mobile I is no longer a straight Group IV oil (PAO base oil).
. Why do they always change anything thats good?
I did not know that the 0W40 would break down faster than the 15W40.....interesting.
I know this has been discussed before - any problems switching back and forth between dino oil and syn?? I really need the syn in the winter. I currently do this and have noticed some oil leaks but I dont think they are from changing oils.
Thx Bill !!!
That pretty much sums it up..
If you look in the owners manual it will give you a range at which certain oils will run in your vehicle. It is true that the synthetics will run out of this range but only so far.
I still run Dino oils as I see very little advantage in running the expensive synthetic oils since they dont stay in the pan for more than 8 weeks at a time.
In the winter I use ROT T 10w30 and have done that in both my trucks since I had them with no troubles.
Even the 10w30 can be run in fairly far into the nice weather without any trouble.
Jason
Agreed, synthetic in this part is darn near mandatory
(-30 to -40 also) , unless truck is plugged in all the time
Mine starts instantly in winter with Mobil 1 10w30(even without being plugged in), less clatter, instant oil pressure, and less wear on internals of engine, as most engine wear is in first minute of startup.
Follow manual with your temp. range to determine viscosity of oil required. Syn or dino your call, both work good in certain applications. You pick which one suits you best based on oil change intervals, hiway vs. city(stopngo), idling, towing, etc.. If you don't tow in winter, viscosity spread break down ( 25 points as Infidel, and rjohnson stated) is not near as critical though, as you may not require 40w rating protection.
Mine starts instantly in winter with Mobil 1 10w30(even without being plugged in), less clatter, instant oil pressure, and less wear on internals of engine, as most engine wear is in first minute of startup. Follow manual with your temp. range to determine viscosity of oil required. Syn or dino your call, both work good in certain applications. You pick which one suits you best based on oil change intervals, hiway vs. city(stopngo), idling, towing, etc.. If you don't tow in winter, viscosity spread break down ( 25 points as Infidel, and rjohnson stated) is not near as critical though, as you may not require 40w rating protection.
ClassA4x4
May 16, 2013 11:49 AM
IPDiesel
Dec 29, 2010 09:21 AM
rufushusky
May 10, 2009 12:41 PM
realoldandcrust
Feb 14, 2008 09:53 AM
rico334
Jan 3, 2005 08:10 AM
