Sponsored by:
Sponsored by: CARiD
Do you guys (and gals) shut down while fueling up?
Old Jan 22, 2007 | 12:17 PM
ptgarcia's Avatar
Well, do you? I don't...should I?
Old Jan 22, 2007 | 12:19 PM
bnold's Avatar
I don't...
Old Jan 22, 2007 | 12:20 PM
Gunrunner's Avatar
I don't unless I am going to check the oil.
Bluedeviltorque's Avatar
Always... and as far as I know its still a law CT too.... I'll have to look it up to see if its still on the books.
Mike
dodgepower88's Avatar
I shut er down cause most fuel stations that i've been to (excluding truckstops) have the stickers that say shut off your engine and no smoking.
Old Jan 22, 2007 | 12:24 PM
White00's Avatar
I have to, my fass bypasses so much at idle it will build up pressure(I guess) and blow fuel out at me. That was not a good surprise on a cold winter morning! But, I never did before the fass.
Old Jan 22, 2007 | 12:32 PM
LJTyre's Avatar
^ yep, not sure why, but the FASS will give me a nice #2 shower i leave it running. (I mean SOAKED)
Not on any other diesels though.
Old Jan 22, 2007 | 12:34 PM
Shovelhead's Avatar
Administrator / Scooter Bum
...sometimes yes, sometimes no.
No real reason, just depends on my mood.
Old Jan 22, 2007 | 12:44 PM
madhat's Avatar
Administrator/Jarhead
Nope. I would rather leave it running. Ain't it bad to shut a diesel off then start it right back up again? That's how I grew up. Anything less than 5 minutes, leave it running.
Old Jan 22, 2007 | 12:49 PM
JyRO's Avatar
Depends on what I was doing before I pulled in. I always let it idle a minute or two anyway. If I have just pulled off the interstate towing, I will let it idle 5 full minutes and shut it down. I take longer than 5 minutes to refuel so mine always winds up turned off. As long as the turbo has cooled off, I don't see any problem with shutting it off.
Old Jan 22, 2007 | 12:50 PM
blackdiesel's Avatar
Registered
id leave it running, but i have to go inside to pay dumb diesel pumps aint got the card.
so i want to pull the key, otherwise id leave it runnin
Old Jan 22, 2007 | 12:57 PM
74dart's Avatar
Depends some times I do sometimes I don't. If Ive been pulling for a while I will not I just go to the truck side they don't have any stickers on the pumps. Also I thouht the shutdown law didn't apply to diesels.
Old Jan 22, 2007 | 01:14 PM
overcomer401965's Avatar
Leave it runnin most of the time.
Old Jan 22, 2007 | 01:17 PM
t-boe's Avatar
I shut down. I check the oil and drain any water from the fuel filter. Probably not necessary, but DC recommends it.
Old Jan 22, 2007 | 01:25 PM
Snapper's Avatar
if it's not at full operating temps, or the cab is cold and I've only drivin a few miles I'll leave it runnin, or if it's hot outside I'll leave it runnin for the AC. No point in shutting it off, then gettin back in a cold or hot truck. And usually I have women in the truck that I have to keep happy!!!
