Sponsored by:
Sponsored by: CARiD
Diesel Conversion
Old Nov 18, 2006 | 10:46 AM
induchman's Avatar
Originally Posted by qamorgan
Ok, the 4bt is the choice ......... will beef up the suspension. What about the transmission which is also going to be rreplaced
Put in an Eaton five speed instead of standard Dodge tranny.
Old Nov 12, 2007 | 11:08 PM
junkenpo's Avatar
Talking I'd do it if it is a ....
I have a '98 Ram 1500 with a blown engine and want to convert to diesel. What options do I have??
I would do it if it is a 4x4, however, if it is to be a daily driver I'd consider a turbo'd 5.9 12valve with an automatic transmission with xfer case. I have built diesel drivers from the late 60's to present, stuck a 3-53 Detroit into a 1952 GMC panel with a modified cab that resembled "RESCUE 9" from the TV series.
The 3-53 got pulled and in 1974 it went into a 1964 Jeep Gladiator ahead of the the original Jeep trans. To do this install, a 4inch lift between axles and springs was needed to just make up the difference between the center of the crankshaft and bottom of the block. I ran with the Jeep five lug sixteen inch wheels running 7.50 X 16 rubber. This combo gave me 60 mph at 2800 rpm in direct (4th gear), as for pulling it was nuts.
In 1979 gas hit $0.66/gal in Hawaii and I thought it was the end of the world, I had a 1975 Ford F250 4X4 that got about 9 mpg with a 300cu in six. I did a re-power using a Perkins 6-354 in-line six coupled to the Ford New Process 435 transmission for 128 ft/lb of torque at 1400 RPM.
On all of these conversions the big factor was good old "common sense", I never had a screwed clutch or twisted drive shaft, well except for the jeep.
With the Jeep I fried the clutch pulling a trailer with a small CASE track loader from sea-level to above 2600 feet, clutch failed at about 1800 foot elevation.
As for the RAM 1500 I'd keep the original axles with 5 hole lugs and I'd learn to drive by feel. Good luck, - Bill
Old Nov 13, 2007 | 05:29 AM
kevellis32's Avatar
Here is probably your best option...Sell what you have now, and buy a 2500 diesel, much less of a headache down the road!
Old Nov 13, 2007 | 11:54 AM
96_12V's Avatar
Exactly....
Not to mention, they're getting cheap now!
For those naysayers, who constantly argue whenever anyone throws reality into the picture in some manner, I simply would communicate the following. Please re-invent only wheels that need re-inventing.
Otherwise, do something original. It's your choice and $$$$ in the end!
Cheers!
DieselMuskrat
Mar 25, 2005 06:55 AM
cmnspwr
Feb 5, 2005 11:51 AM
azfullthrottle
Jan 2, 2005 11:04 PM
PeteRR
Apr 12, 2004 05:26 PM
CMN_NOT_STROKN
Oct 29, 2002 09:53 PM
