Is the Cummins still the best??
Valid points. In your comparison, though, you compared the HD motor's predicted overhaul interval to the cream of the crop 12v stories. MANY 12v engines will not make it to a million miles without an overhaul. There are those that have (same as the 7.3 IDI), but it cannot be expected. Cummins' expected overhaul interval on a 12v is FAR less than a million miles, so the comparison is more than slightly biased. You're comparing the standard expected life of one engine to the top-tier stories of heroism of another.
Also, you have to remember what the HD Cummins motors are subjected to. In an industrial gen-set application, the motor sits for months, then is required to fire up and assume full-load immediately. This is very taxing on an engine, which is why the life expectancy is lower than expected.
Sent from my DROIDX using Tapatalk
Although I agree to some degree that this abuse is a contributor to the shorter life expectancy, I am also of the strong persuasion that the "V" design wears the cylinder walls in a diesel much quicker due to combustion characteristics and all the other things that go along with it like harmonics.
Most guys that run V8 diesels (that think they love them) will tell you they are fine as long as you don't lug them. I'm a lugger
Good thoughts, but I still don't agree that the 12v has a longer service life than the Q-series Cummins. And yes, in the big gen-sets, reliability IS paramount. It is important in medium duty applications, for sure, but it is FAR more important in the HD Stationary market. My company just recently completed the Google Atlanta facility ( GC) with 2.1 billion ( with a B) in infrastructure backed up by Cummins Q-series stat. setups. The budget was unlimited, and there were no space requirements. It was, and still is, one of the most monetarily important scenarios on earth that relies on a mechanical engine. They use Cummins Vee motors. If you think any engine manufacturer would send a subpar platform (as you're implying the Vee motor is) into such an arena, you're mistaken. Cummins has plenty of faith in the Vee orientation for some reason...
IMO, Cummins wouldn't sacrifice their legendary name by widely implementing an inferior design solely based on space efficiency and weight management.
As bad as I hate to admit it I think Cummins has lost it`s advantage. There was a time that dodge had much better fuel mileage, the same HP, & tough as nails. Now the other trucks have more power & better fuel mileage. As far as the engine it looks to me like the GM has less trouble than the others & has a service department that knows how to fix it.
Banyon,.....I agree with you! I also think Cummins has slipped over the past three to four years. IMHO,.....the emissions issues have hurt them more than anything. As you said, the mileage of the new trucks is terrible, I see constant problems with the engines at my local Dodge Dealer and as you also said the new Dodge CTD CR 6.7's are dead LAST in ALL categories when they go up against the new Ford 6.7 and Duramax 6.6. The most recent
"shootout" between the new Dodge 6.7, Ford 6.7 and Chevy Duramax in "Diesel Power" proved that.
Like you, it pains me to have to say this as I have driven Cummins Powered Dodge Trucks since 1992. And I can honestly tell you that of the five that I have owned my 1996 Dodge CTD 12 valve is still the BEST of all of them that I have owned.
John_P
i'm not sure what these v motors are being used for at gooole but it looks like from what you stated is that they are being used for generators or something along those lines which is a far cry from a engine thats used for a half a million miles of service hauling loads all over the country.there's no way these engines you spoke of are going to see the run time or heavy loads our trucks will see during their life time.
You're thinking of a backup generator, which is seldom used. Way different.
There may be a whole different reason for using V8 configurations for generator plants, more power pulses per rotation. This can be a big benefit on the generator.
Why doesnt someone ask cummins why they use what they use?
I work on power generators but they use Nat. gas turbine engines, i do know the generator can be very finicky in how they are spun.
SMH. Stationary generators run all day, every day @ full load. They also have to do that without the benefit of increased airflow which comes from speed that vehicle engines enjoy. These engines log use in hours or fuel consumption, not miles, but if you do the math, the miles would be in the millions....
Lack of "increased airflow which comes from speed that vehicle engines enjoy" is offset by a larger cooling system. No increased airflow needed.
I did the rough math for ya - L6 came in up top of the V8.
) By the way, not all the Q-series Cummins are V configurations.
I think they all suck do to the electronics. You can not even change your own injector without the factory programmer to put serial numbers into the computer. Look at the price for a injection pump or set of injectors. 12k for a newer 6.7. We have let the Automakers enslave us with having to have them repair most of the most common failures. I had to make a choice and went with a straight six because of less parts than a 8 and less shop time due to access.
. I did this with my 92, 01 and 08. My best truck was the 92 and wish I would of just payed to do a frame up restore / rebuild. In 395k the 92 cost me $800 in repairs beside maintenance. In the 01 it was $5400. So far on the 08 warranty has covered everything but as the miles build it scares me to heck.
. I did this with my 92, 01 and 08. My best truck was the 92 and wish I would of just payed to do a frame up restore / rebuild. In 395k the 92 cost me $800 in repairs beside maintenance. In the 01 it was $5400. So far on the 08 warranty has covered everything but as the miles build it scares me to heck.DING!DING!DING!
That being said, I really wouldn't want to go back to the "bad old days" of zero emission controls...
Who else remembers choking on the black smoke and diesel fumes eminating from a three/five ton cube van in front of them in rush hour traffic? Or choking with watering eyes on the vapors from several poorly tuned carburated V8 gas engines on a hot summer day?
Yup, emissions control pisses me off, but only when it comes to the vehicles I own. Everyone else needs it... Does that make me a hypocryte?
My father had a 95 powerstroke, and 1) it made respectable power and torque in stock form, and 2) it was definitely stronger than my stock 94 12 valve- I hate to say it, but it is true. Of course, his 7.3 had a manual transmission, while I have an auto. Saying that, there is no comparison to how simple and cheap my 12 valve is to work on, compared to that 7.3. I have opened the hoods and scoured the bays of a new powerstroke and an earlier duramax, and you can hardly see daylight, much less work on them easy. My brothers 08 6.7 Dodge has a lot more stuff than my 12 valve, but you can still work on it. I am a firm believer in an inline 6, and being able to work on it myself. So, in my opinion, I would take the Cummins over the other two, regardless of their power differences.
I think it comes down to apples to apples. I read on here one guy saying his friend had a 7.3 and had 600hp and lasted two weeks. Sounds like he was playing and ended up paying. It's not a Ford or International issue if I take their engine and put on a huge turbo, garden hose injectors and then end up spitting a rod out the side of the block. I abused my rear differential, killed it and it has cost me over $2000 so far, am I ticked off at Dodge, nope, it's my fault, now, talk to me about the dash that is falling apart and I'll give ya an earfull!
My buddy is a Ford tech, says 90% of the Ford 6.0's he sees with head gasket issues, injectors are the one's where the guy has thrown a chip on it. Other than that he tells me that they are just common egr problems and things, kinda like the fuel system fiasco I have dealt with on my Cummins. We had an F550 and it had some oil leaks but that was about it. It got drove hard for 50k with my butt in the seat and just some oil leaks. Another fella said the new 6.7 Fords are having oil pan gasket issues? Wow, mine on my '02 Dodge was leaking when bought it, had it fixed under warranty and was leaking a year later. I have a contractor friend who has an '01 Ford F250, 7.3. Has done nothing to it except maintenance. He did all 8 injectors and it was paid for by the gas station that sold the dirty fuel. Other than that he has done nothing else. Over 300k on the ticker.
I'm not stickin' up for Ford but like I said, apples to apples. Don't throw thousands of dollars of power adding junk to your engine and then blame the manufacturer when it breaks. Man up and accept the fact that your gonna have to reach deep into your pockets.
As far as the big three. I don't know much about the new Dodge, with all the fuel pump issues on mine, dash problems, clutch, tranny, on and on(before I added any power) I'm going to jump ship personally. I know, I know, everybody has their issues, guess I'm gonna revert back to what I grew up on.
I've heard rave reviews for the new Ford engine. If I was willing to spend $50k plus on a cab and chassis I might give it a whirl but the case of the $50k is what gets me. The current 6.0 Powerstroke incident reminds me of GM many years ago when they decided to put a diesel in a car and it ended up turning into a giant mess. A blurb on GM's history, something which they have obviously overcome with the Duramax. Same thing happened to Ford for whatever reason they've now got this blip on their record.
As far as the Isuzu engine, don't get caught up in your little world. Isuzu is very large in Japan and has big engines as well, up to 15.7L engines, Marine and industrial applications. http://www.isuzuengines.com/series_f...p?series=C_IDI What you see over here is just a fraction as they are not big in our market with the CAT, Cummins and Detroits populating most heavy trucks. Go to Japan and you'll see Nissan, Isuzu and others dominating the highways.
What's the best? In my opinion(which is like a bunghole, everybody has one) there is no single best. It's all opinion. You can't build and test in indentical conditions to prove it in any way. It's all opinion, this guy buys into the herd mentality and buys brand "W" diesel, this guy was raised on brand "Y" and that's what he calls the best. We have all seen it and read it right here when somebody say's, "I'm done with Dodge" and the usual first response is, "sorry to hear that bud, but your gonna find everybody has their own issues". Every driver drives, maintains his vehicle in different ways. This one has fuel issues, that one has egr issues, etc., etc.
Is Cummins the best? In my opinion no. Good engine, yeah it has done what I needed it to do. Reliable, yeah, most issues I've had have been dodge induced.....or the most recent induced by me! As far as the best, I honestly can't say anything is the best. The best in my opinion would be one that you can climb into day in and day out and know for a fact that you will get home that night, a vehicle that would put the wrecker business and mechanics out of business. But, as humans with everything made by humans that is as likely as traveling at the speed of light.
I think it comes down to apples to apples. I read on here one guy saying his friend had a 7.3 and had 600hp and lasted two weeks. Sounds like he was playing and ended up paying. It's not a Ford or International issue if I take their engine and put on a huge turbo, garden hose injectors and then end up spitting a rod out the side of the block.....
and it lasts 3 years and my buddy builds 600hp into his 7.3l Powerstroke and it lasts a couple weeks, how is that not apples to apples? They are both the manufactures chosen engine, they both do the same job, see the same abuse, they both have "garden hose injectors" and big turbos etc etc etc.You want to talk apples to apples? The Cummins is a small inline 6 cyl against the bigger V8 7.3l. And yet still, the smaller engine is making more HP/Litre (in this specific case) and lasting longer. The Cummins longevity is not just in this scenario. The Cummins as an average outlasts any of the Powerstrokes on an average. Especially when power is added. This includes towers, daily drivers, abusers etc. Apples to apples. Makes Cummins better in my books.Also, the identical testing facility is out there - it's called the real world. A world where there are millions of each engine all sharing the same conditions and the Cummins is just known to outlast the competition - added power or not.
Yep. That right there is a fact.
