Sponsored by:
Sponsored by: CARiD
Cooling problem with my Transmission
Old Aug 4, 2007 | 11:05 PM
AFDan52's Avatar
Unhappy Cooling problem with my Transmission
I was sitting in some pretty heavy traffic due to some constuction and was watching the engine temp climb a little as I figured it would do. It was about 15 minutes before I could get going again, once i was able to move out of there the transmission started slipping pretty bad. I feathered it some just to get out of that area and it did get a little better in the other gears , but still slipped in the 1-2 shift. My question is why would the transmission fluid get that hot in that short of time. Also Do any of you have any suggestions as to how I can fix this ?
Thanks AFDan52
1998.5 Dodge 2500 Quadcab 4X4 Shortbed Auto with a shell, Stock Stock Stock
Old Aug 5, 2007 | 10:20 AM
JKM's Avatar
JKM
You would be surprised how hot the transmission fluid will get with the engine idling, transmission in gear , and not moving. The TC will constantly be making heat, and there is almost no air flow across the cooler , the engine temps will be hotter for the same reason, and that will not help the heat exchanger cool the transmission fluid either.
There are a couple ways to "fix" the problem, you could add an under bed transmission cooler with an electric fan on it, or just put the transmission in N ( not park , as it does not pump fluid in park) when your not moving.
Old Aug 5, 2007 | 10:36 AM
OutlawStorm's Avatar
Stock Transmission ONLY dont pump the fluid in park. Most all rebuilders fix that when they rebuild it. I know Goerands for a fact pump fluid in park as he told me that himself when he installed mine.
Old Aug 5, 2007 | 12:42 PM
infidel's Avatar
Putting it in N and turning off the A/C will go a long way.
Old Aug 5, 2007 | 01:51 PM
Exactly right there Infidel.... I found also when in neutral, to bring the rpms up a lil to to help get the fan to spin faster
Old Aug 5, 2007 | 06:06 PM
Joker12valve's Avatar
I put a 10"pusher fan on my truck in front of the trans cooler, put it on a switch. keeps the temps around 150 in stop and go traffic.
5.9Excursion
Nov 29, 2007 12:46 PM
trapperff
Jan 29, 2007 07:55 PM
edtyler
Dec 13, 2006 09:35 AM
gregn
Jul 23, 2006 03:26 AM
mopar2ya
Apr 1, 2004 06:42 AM
