Sponsored by:
Sponsored by: CARiD
Can't go far enough
Old Oct 24, 2005 | 05:36 PM
jimmykirby's Avatar
Can't go far enough
Need to know the best way to increase the amount of diesel storage without filling up my truck bed. has anyone tried one of the replacement tanks and if so how did it work and how hard was it to replace? Any other options would be appreciated. I have recently started using biodiesel and would like to fill up with more because none is available real close to me.
Old Oct 24, 2005 | 07:20 PM
Dorkweed's Avatar
Muted User
From: "The Peoples Republic of Illinois".....behind enemy lines
Do a search under "Fuel Tank Vent Mod". You'll be able to get about another 3-4 gallons in the stock tank!!
Old Oct 24, 2005 | 07:30 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Use my "Poor Man's Aux Fuel Tank" method.
Buy a bunch of 5 gallon fuel cans, fill em up when you take the truck for a refill, then store the full cans in the garage.
Old Oct 25, 2005 | 07:22 AM
Fronty Owner's Avatar
Here is an idea some friends of mine and I are kicking around.
Move the exhaust to the outside of the frame (Kinda like side pipes, but tucked under the body)
Add a Second fuel tank to the other side of the drive line where the exhaust used to be.
"T" into the fuel fill line to fill the new tank at the same time as the main tank.
Add appropriate directional solenoid valve to switch between tanks.
Old Oct 25, 2005 | 10:44 AM
infidel's Avatar
Take note that unless BD is stored in a container filled totally to the top with no air or light and isn't opened that it starts going bad in about 45 days then progresses rapidly after that. Basically it goes rancid and doesn't lend itself well to stockpiling.
There are antioxidants available to prevent this but add to cost of the BD and are not provided at the pump, you have to add them yourself.
Old Oct 25, 2005 | 04:13 PM
usmc2311's Avatar
If you are looking for a larger tank and not fill up your bed you can check these guys out: http://www.aerotanks.com/ They make replacement tanks that fit in the OEM location (up to 60 gals, if I remember correctly).
Old Oct 25, 2005 | 06:35 PM
nickleinonen's Avatar
i wouldn't mind having another tank mounted where my spare tire use to live... it's been in the bed for over a year now anyways... just build a tee fitting to fill both tanks from the same filler, and have like a 1/8"-1/4" crossover pipe between the tanks, so slowly the aux tank will fill the main until the levels equalize, and if something broke on that line, it wouldn't be a massive leak. i wonder how a 140 liter suburban tank would fit aft of the rear axle???
Old Oct 25, 2005 | 06:42 PM
Hoss's Avatar
Thats MR Hoss to you buddy!
True, except that as far as I can tell that particular kit isn't available anymore. I've wondered how hard it would be to make my own though.
Old Oct 25, 2005 | 07:50 PM
Begle1's Avatar
Won't a tank out of a Ramcharger fit in that area for a first gen?
Old Oct 25, 2005 | 08:38 PM
jrkerns's Avatar
I would love a bigger tank, but I'd have to take out a second mortgage to fill it up....
Old Oct 26, 2005 | 09:53 AM
05mxdiesel's Avatar
This kit is still available, mine just showed up last week. Heres a link:
http://www.turbodieselregister.com/c...uery=retrieval
Totallyrad
Jul 19, 2011 07:41 AM
92smokin blacky
Feb 23, 2011 07:18 PM
hamilton71801
Dec 20, 2007 12:15 PM
Boatnik
Aug 5, 2007 09:09 PM
FNJ
Jul 9, 2006 12:45 PM
