Sponsored by:
Sponsored by: CARiD
bosh ve pump. 89 vw golf n/a diesel
Old Nov 26, 2007 | 08:30 PM
dj_souvlaki's Avatar
was wondering if i can get a little help. seal was leak. removed top portion that houses the throttle shaft. well my buddy did for me when i was at work. now the car barely idles and wont rev up. called around and people were telling me that the spring was incorrectly installed.
anybody have any diagrams or pictures of the pump that can help me out?
Old Nov 26, 2007 | 10:36 PM
TravisDj's Avatar
PM me with your email. I have done A LOT of work with this type pump, had the same problem also. I will email you with a lot of info. You are close to running though.
Old Nov 27, 2007 | 11:38 AM
i found some diagrams the way i figure is i haven't installed the spring properly. at work right now and can't check my e-mail but send it anyways. thanks.
Old Nov 27, 2007 | 01:24 PM
Ilikebikes's Avatar
May even wanna check in on the first gen forum here. Lots of VE pump gurus there.
Old Nov 27, 2007 | 09:58 PM
Buckshotmckee's Avatar
Just PM'd ya a link! Hope it helps.
Old Nov 28, 2007 | 04:18 PM
JKM's Avatar
JKM
Hmm , this sounds familiar , I have a friend with 1990 Golf NA diesel , and about every 6 months it will start acting up , all it will do is idle, it will not rev up any.
Our fix this far has been to put a reman IP on it , is there another fix?
Old Nov 28, 2007 | 05:08 PM
The original poster's problem is that the throttle lever is not indexed properly to the shaft. Pull the lever off, rotate the shaft counter-clockwise 1 spline, and try again. When it idles normal with the idle screw set where you had it before, you have it right.
Old Nov 29, 2007 | 12:05 PM
i got it runnning good now. screwed around with the smoke screw a bit too. now just gotta fix my temp gauge. fix one thing and another arrises.
JWC-PERFORMANCE
Jun 14, 2007 10:18 PM
mr T
0
Feb 5, 2005 10:35 PM
Diesel-Dan
Jan 6, 2004 02:19 PM
BamBam
50
May 23, 2003 09:38 AM
