Sponsored by:
Sponsored by: CARiD
Boost and EGT questions
Old Apr 27, 2006 | 11:18 PM
wayne74447's Avatar
I just bought a 1993 ram with the cummins in it IT has a banks wastegate actuator and banks guages. The issue i am having is the boost never goes above say 13 psi and egt 400 degrees at most. Weird?? maybe guages off or is there something else i should look at??
wayne
Old Apr 28, 2006 | 12:35 AM
Deezle98's Avatar
Well where to start? First gens didnt come with gated turbos stock, so therefore it must have had a gated housing put on it to use a wastegat actuator. 13 psi is about the stock level for a first gen, I also assume the fuel wasnt turned up at all on this truck so therefore no increase in boost, egt, or power would be had. And as far as 400 degrees for you egts I would also assume you pyro probe is mounted post turbo which shows innacurate readings and I would advise having the pyro mounted pre tubo for accurate readings.
Old Apr 28, 2006 | 01:24 AM
Teddy Bear's Avatar
Yeah sounds like your pyro probe is mounted post turbo. Which can cause the gauge to be off as much as 400*. Take it out, and mount it pre turbo. You can buy a 3K GSK for those trucks for really cheap (Im thinkin $18 but not for sure). It really helps the 1st gens out though.
Old Apr 28, 2006 | 01:31 AM
Teddy Bear's Avatar
With the combination of the GSK and a little pump work, that truck will run better than it ever has. Heres a link on how to get some more fuel outta the pump http://dodgeram.org/tech/dsl/more_power/Power_ve.htm
missouriman
Jan 25, 2011 12:27 PM
finndogg54
Jul 29, 2007 05:43 PM
Ghost Ram
31
May 18, 2007 08:56 PM
Mopar72
May 23, 2006 10:57 AM
truckjunkie
Sep 14, 2004 07:27 PM
