Sponsored by:
Sponsored by: CARiD
Biodiesel
Old Oct 4, 2002 | 03:44 PM
rattle_rattle's Avatar
Biodiesel
Has anyone used it? Is it expensive? Does it smell like french fries cooking ???
Old Oct 4, 2002 | 07:27 PM
admin's Avatar
Re:Biodiesel
Never tried it. What does it consist of? Can these trucks operate with it safely?
Old Oct 5, 2002 | 08:20 AM
Re:Biodiesel
Jack,<br><br>The link below gives more info than I can. I did a forum search here and found no references to it so I just wondered if anyone had any experience with it.<br><br>Biodiesel Information<br><br>Regards,<br>Gary<br>
Old Oct 6, 2002 | 09:06 AM
thatguy's Avatar
Re:Biodiesel
Thanks for the website Rattlin Ram.. very interesting, very interesting...<br><br>the site mentioned that the biodiesel met some ATSM specification (or some other initials).. does that spec meet D/C specificiations as well?? <br><br>I know the 12V could/would run on just about any distillate.. the 24V had a much smaller list of 'alternative' (as in the aviation/jet/kero) fuels due to the fuel pump needing to be lubed..<br><br>just wondering..
Old Oct 7, 2002 | 06:53 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Re:Biodiesel
[quote author=thatguy <br><br>I know the 12V could/would run on just about any distillate.. <br><br>
<br><br>Hides those quart jars of...errrr.... furniture polish I had stuck back in the cabinet ;D
Old Oct 7, 2002 | 08:49 PM
phox_mulder's Avatar
Re:Biodiesel
If it's just the fact that the VP44 needs lubrication.<br>You should be able to run a 24V on anything the 12V could, just add a quart of engine oil with every fill up.<br><br>Or some of the snake oil fuel additives that lubricate. :-X<br><br><br>phox
Old Oct 7, 2002 | 10:15 PM
Re:Biodiesel
After posting the topic, I went on a little biodiesel search. I found this site. I found it very interesting. It may not be very practical yet but it makes for some interesting reading.
Old Oct 10, 2002 | 11:21 PM
admin's Avatar
Re:Biodiesel
Lots of info. Looks pretty scary though. I wonder how long an engine would last with that. Has anyone tried it?
Old Oct 11, 2002 | 11:38 AM
Doubleclutch's Avatar
Re:Biodiesel
I did some research on this last year and found that the typical biodiesel fuel was a 80%dino/20% biodiesel mix. The biodiesel has a little less btu content, so I couldn't get the company to switch over (6 4300hp Alcos emergency generators with tankage barely adaquate), and lost interest. Still a little more expensive than dino diesel, but is starting to become available in S.F. and L.A.<br>It's possible to make your own but I'm not up to it. Would look pretty hard at the VP44 specs. Greg
Old Oct 12, 2002 | 04:04 PM
Bob Beauchaine's Avatar
Re:Biodiesel
I saw a Shell station in Portland OR advertising Bio-diesel for $1.759 per gallon. Regular diesel is running about 35 to 40 cents cheaper depending on where you go. <br>Bob
Old Oct 13, 2002 | 08:52 PM
Fishcop's Avatar
Re:Biodiesel
Farmers are using it around here...... Eastern Va.
Old Oct 15, 2002 | 06:01 AM
Commatoze's Avatar
Re:Biodiesel
[quote author=phox_mulder link=board=8;threadid=5566;start=0#49623 date=1034041743]<br>If it's just the fact that the VP44 needs lubrication.<br>You should be able to run a 24V on anything the 12V could, just add a quart of engine oil with every fill up.<br><br>Or some of the snake oil fuel additives that lubricate. :-X<br><br><br>phox<br>[/quote]<br>As a matter of fact, I've read that some guys are doing just that, adding a quart of synthetic, low ash, 2 cycle motor oil at each fill-up.<br><br>-Tom-
Old Oct 19, 2002 | 05:30 AM
AlpineRAM's Avatar
Re:Biodiesel
Over here biodiesel is a tad cheaper than regular. I use up to 80% bio in summer, up to 60% in winter. Due to higher cetane numbers you have to retard timing a bit. Due to the higher lubricity and the higher viscosity of bio the VP44 runs almost silent. You have to up fuel pressure to achieve a good filling of the pump element at WOT at high RPM.
I've been driving the RAM for about 50k miles on these mixtures.
Warning- there is almost no possibility to produuce black smoke if you have a high % of bio. EGTs are actually lower if you have the timing set right. Fuel consumption is a tad higher ( lower energy content)
Edit- the smell depends on what is used to produce the biodiesel- If its used cooking oil you smell the steaks, fries or whatever. If new plant oils are used the smell is less than on regular diesel.
HTH
AlpineRAM
Old Oct 22, 2002 | 09:09 AM
dhe9's Avatar
Re:Biodiesel
used cooking oil. dam, i wouldn't mind it smelling like steak and lobster . only problem here in the granola state is some freak in san francisco would be trying to drink it .
Lightman
Aug 8, 2003 08:40 AM
woodrat
Jan 9, 2003 11:29 AM
driver
Dec 22, 2002 09:21 PM
98rammer
Dec 22, 2002 04:55 PM
