Sponsored by:
Sponsored by: CARiD
4bt
Old Dec 29, 2008 | 12:10 AM
94ram's Avatar
4bt
does any one know how to bleed a 98 case 580 super l or 4bt. thanks
Old Dec 29, 2008 | 07:26 AM
jrs_dodge_diesel's Avatar
Bleed? Bleed what, the injector lines or the hydraulic system?
Old Dec 29, 2008 | 12:07 PM
j-fox's Avatar
If you ran it out of fuel, you need to loosen the fuel line at the injection pump. Then hand pump the lift pump. If it doen't feel like it is pumping, turn the crank 1/2 turn. Once you get fuel, tighten up the fuel line and pump a little more. You may need to loosen the injector line at the injectors and crank it until some are dripping fuel. Tighten them back up and it should start.
If you don't get fuel it may be gelled or have a case of algea.
Old Dec 29, 2008 | 11:46 PM
deerslayer1979's Avatar
Crack a couple of injector lines, at the injector, and turn it over. I may take a little bit but it beats the hell out of having to hand pump the system. And before anyone tells me it will destroy the IP, the starter won't turn fast enough to get the IP hot or to smoke the bearings. I would however fill the fuel filter before rolling it over.
DS79
Old Dec 30, 2008 | 01:07 AM
94ram's Avatar
thanks guys
i did the lift pump and opened the lines, it started right up. im thinking that there is crack somewhere in the fuel lines because we always get this problem
Old Dec 30, 2008 | 09:36 AM
Mrlou's Avatar
The 1/2" i.d. rubber fuel hose between the lift pump and the injection pump on my 580 had a couple of hairline cracks that went unnoticed because everything is painted black, I found them by squeezing the hose. After replacing the hose it doesn't lose prime after sitting. Good Luck
racinrex
Jun 4, 2009 12:54 AM
spunbearing
Aug 9, 2004 07:53 AM
mcinfantry
Jul 21, 2004 10:42 PM
driverswanted
Jul 8, 2004 10:22 PM
1340
Feb 12, 2004 11:26 AM
