Sponsored by:
Sponsored by: CARiD
4bt ??
Old Jul 21, 2004 | 10:22 AM
spunbearing's Avatar
4bt ??
I know this is off topic for the first gen group but does anyone know anything about the 4BT? I have an old series 3 land rover and I'm considering a 4BT conversion but I can't seem to find much info on the engine. Weight, physical size etc. Also where I can find one with the proper governor setup so I don't have to rebuild everything. Someone told me a fedex truck or frito truck. Any ideas????
Old Jul 21, 2004 | 04:06 PM
Cummins web site has spec sheets on the ISB4, the size and weight haven't changed much. The 4BT is still available as an ag/industrial engine so you might be able to dig up specs for it there too. Bread trucks/step van type vehicles are the best place to find them. TDR has a good engine swap forum, you might want to read through that.
Old Jul 23, 2004 | 08:35 AM
MR.M's Avatar
I have a 4bt for sale i just put it up in the 2nd gen. drivetrain classifieds, it's goin for $1500. PM me if you are interested or have any questions. You can also find pics of it at http://community.webshots.com/user/mordy37 under 4BT.
Old Jul 23, 2004 | 09:33 AM
Mechanos's Avatar
What are some common sources for the 4BTA?
Old Jul 23, 2004 | 05:37 PM
The "A" just means it's intercooled. If you can get the original intercooler that came with the engine you've got a 50/50 chance it will fit where it needs to go. I wouldn't go to any extra lengths to find a 4BTA, you can add an intercooler to any 4BT.
Old Jul 25, 2004 | 07:41 PM
moparguy's Avatar
I understand some 4BTs had a special balancing package. Anyone know what this is and how to identify a engine with this option. And how well does it work.
My as yet unstarted pet project is a 4BT W150 or Ramcharger.
Old Jul 25, 2004 | 10:41 PM
Mechanos's Avatar
When I was talking to the Cummins Tech guy, he told me that "A" does indicate aftercooled. However, he did say that most of the 4bta's used a water-to-air aftercooler in the intake manifold instead of an charge-air aftercooler like the ones found in our Rams. It doesn't matter what kind of aftercooler it has... they both are designated by an "A".
FWIW... he also told me that the water-to-air aftercoolers were capable of bringing the intake air down to around 250° and the charge-air coolers are capable of getting the air down to about 200°.
Old Jul 27, 2004 | 10:28 AM
Mostwanted's Avatar
There is one for sale in our local newspaper for a little over $3K right now
Old Jul 27, 2004 | 01:06 PM
Mechanos's Avatar
For just the engine? I'd say that unless it's fairly new, low miles and superbly clean, that's a bit on the high side.
Old Jul 27, 2004 | 03:17 PM
Mechanos's Avatar
Mostwanted...
Which paper?... I looked through a couple and didn't see it.
Old Jul 28, 2004 | 09:46 AM
Mostwanted's Avatar
kansas city star
in the auto or truck parts and accessories
Old Jul 28, 2004 | 11:34 PM
kandgo's Avatar
Tugs, forklifts,Case brand equipment as in back hoes and dozers, bread trucks, ups trucks, power equipment, generators, some farm equip.etc. I would guess the list could go on. Goodluck,,,Rick
Old Jul 30, 2004 | 12:40 AM
mcinfantry's Avatar
i sure like my 4bt. wish i could afford a new isb aftercooled ... 250hp
Old Jul 30, 2004 | 10:27 AM
Mechanos's Avatar
Have you thought about or looked into adding an aftercooler to your 4bt? The water-air aftercooler (while not as effecient as the charge-air aftercooler) might be the best bet if space in front of the radiator is at a premium. By adding the aftercooler, you should be able to play around with hopping up the pump and/or different injectors and still keep your EGT's under control.
Old Aug 2, 2004 | 01:00 PM
mcinfantry's Avatar
i honestly dont know enough about them. the air crossover tube is almost toching the hood, so i dont know how highh the after/inter cooler stuff is. i really wish i could see one before i tried it and it didnt work
while if money was no object id like more power, to be hones im real happy with it, and especially my fuel efficency
