Sponsored by:
Sponsored by: CARiD
4 wire cummins
Old Sep 25, 2010 | 10:03 AM
Ramtough's Avatar
4 wire cummins
Ok so I read somewhere, sometime ago, that the old 12 valves could be run with just 4 wires needed. Battery, alternator, key, and fuel pump. Is that it?
Id like to build a truck as basic as I can get it. Would there be anything else needed? What year would be my best bet to look for a starting point?
thanks for any info you can provide.
Old Sep 25, 2010 | 11:06 AM
6cylinders's Avatar
The fuel transfer pump is mechanical on 12 valve engines,
they are much like the fuel pump on a old chevy,ford gasser.
Old Sep 25, 2010 | 11:34 AM
pind's Avatar
1 for the alternator, 2 for the battery + and - , 1 for the key, and a manual shutdown cable.
That will run it. It won't be pretty, but it will work.
Old Sep 25, 2010 | 12:51 PM
If you convert to a manual shutoff and always park on a hill, you can do away with the whole electrical system.
Old Sep 25, 2010 | 02:08 PM
Ramtough's Avatar
how bad is it will run but wont be pretty?
Thanks for the info.
Old Sep 25, 2010 | 02:17 PM
carl48's Avatar
not that bad. when we use a 12 valve for a pump engine that is basically what we do. we add the mechanical oil and water temp gauge
Old Sep 25, 2010 | 02:21 PM
1-2-3's Avatar
Just a plain ole guy
What about head/tail/brake lamps?
Old Sep 25, 2010 | 04:38 PM
A 12 valve will run the same with electricity or without. The whole fueling system is mechanical.
Old Sep 25, 2010 | 09:43 PM
d22019's Avatar
The 12 valve is like a gasser with a magneto,as long as you have a way to turn it over you don't need electricity to run anything.
Old Sep 26, 2010 | 04:38 AM
Jim Lane's Avatar
If you install a hydraulic or an air starter you can start and run it with no electrical system at all.
Just think after the next massive EMP strike you could still drive into town.
Or you could use a Coffman Starter and scare your neighbors.
Jim
Old Sep 26, 2010 | 05:02 PM
Me want!
duallydave
Jan 22, 2009 04:50 PM
Rollin Smoke
Oct 24, 2006 10:24 PM
Txwelder
Feb 11, 2006 10:32 AM
matthopp
May 11, 2004 04:38 PM
TPilaske
16
Nov 22, 2002 08:15 PM
