Sponsored by:
Sponsored by: CARiD
1999 F-450 Super Duty
Old Aug 1, 2012 | 06:23 PM
frog_jaw's Avatar
Exclamation 1999 F-450 Super Duty
I know its not a Dodge but can you please help? It will not go over 50 miles an hour, it bogs down. It runs great at idle. The turbo feels good, no slack or oil Does this sound like a fuel problem to you?
Old Aug 1, 2012 | 07:09 PM
Hvytrkmech's Avatar
It could be fuel, when was the last fuel filter change? The only way to be sure is to check supply fuel pressure and volume. The fuel tanks had a delaminating issue blocking the pick up sock in the fuel tank. Check that out. Also a faulty fuel regulator will cause a low fuel pressure.
Old Aug 2, 2012 | 06:25 PM
akghound's Avatar
Yes, I would agree it is a fuel problem. Could be lift pump or dirty filter. You should have about 70 psi feeding the fuel bowl (Filter Housing). Carefully loosen top cover of fuel bowl, turn on key but do not start engine. Got fuel? Yes= Probably not lift pump.
Ken Gardner
Polarlys
26
Jan 20, 2017 12:09 AM
dezl-andy
Nov 1, 2009 10:04 PM
I PASS GAS
Feb 13, 2007 09:37 AM
FMB
Sep 5, 2005 01:44 PM
Mexstan
22
Jun 8, 2003 03:26 PM
