Sponsored by:
Sponsored by: CARiD
1982 Internation dump truck with cummins
Old May 10, 2010 | 05:22 PM
West Coast's Avatar
My 82 International dump truck drives and runs great. Today I did a delivery and backed up a steep driveway and dumped my load. When I pulled out the truck had a issue with the idle staying high and not coming down fast enough.....
I was down to 12 gallons of fuel in my 105 gallon tank. I was thinking that the low fuel level may have caused some air to enter the lines when I back up the driveway? Any thoughts on some things to check?
Return spring on throttle is good. Throttle cable is good...... Other than the high idle, truck runs great......
Truck still has high idle after parking the truck. Drove 6 miles from dump spot to my property....
Old May 10, 2010 | 06:09 PM
Hvytrkmech's Avatar
Sounds like air in the fuel system. Fill it up and see if it still does it. I bet it does not.
Old May 11, 2010 | 12:19 AM
West Coast's Avatar
Hvy thanks for the post. I am hoping for the same thing. I will post my findings....
Old May 11, 2010 | 01:57 PM
rich's Avatar
you gotta watch your fuel level in those trucks pick up tube will suck air if to low and going up or down hill
Old May 11, 2010 | 10:43 PM
dieselcamp's Avatar
If the engine is the same vintage of the truck that should have a PT fuels system, common problem is a leaking throttle shaft. Time for a new pump.
gyman98
Cummins Conversions
249
Feb 2, 2016 06:41 AM
johnny5.9
May 7, 2015 10:43 PM
capt.Ron
Feb 25, 2014 07:52 PM
BustedWrench
Cummins Conversions
17
May 5, 2010 11:59 PM
quicker
Feb 17, 2006 07:01 PM
