#1 diesel
#1 diesel
I know that I get #2 diesel out of the pump at the fuel station, where does #1 come from what's it used for and what's the difference between 1&2 and is there any other diesel grades? Thanks for helping me understand
#1 is thinner than #2. Before ultra low sulfur, they would simply blend #1 and #2 to make winter fuel. When ULSD came out, they started using additive packages instead of blending because the #1 was often not ULS.
There are many grades of fuel, the higher the number, the thicker it is. It used to be that #2 diesel and #2 home heating oil were the same until they changed the sulfur requirements.
#1 diesel is similar to Kerosene. The cloud/pour point of #1 is much lower. For that reason some stations up north mix #1 and #2 during the winter months. #1 has less energy per gallon and will reduce your fuel mileage over using #2. With the way electronic engines recirculate fuel back to the tank and keep it warm, most places rely on the additive package provided from the fuel companies to avoid gelled fuel. You have to be in some pretty cold temperatures before you need to worry about mixing #1 in your tank.
Incorrect. #1 and Kero are different. Kero has 0 lube in it. #1 still has a bit although less than #2.
You are right on the money there.
I get straight #1 from the pump here from the end of September until March/April. No blending. I also run additives in every tank to drop the gel point and provide lubrication to the pump.
Mark Hodowanec
Feb 26, 2006 08:35 PM
mdq
Jan 16, 2003 04:59 PM
