#1 diesel
I know that I get #2 diesel out of the pump at the fuel station, where does #1 come from what's it used for and what's the difference between 1&2 and is there any other diesel grades? Thanks for helping me understand
#1 is thinner than #2. Before ultra low sulfur, they would simply blend #1 and #2 to make winter fuel. When ULSD came out, they started using additive packages instead of blending because the #1 was often not ULS.
There are many grades of fuel, the higher the number, the thicker it is. It used to be that #2 diesel and #2 home heating oil were the same until they changed the sulfur requirements. |
#1 diesel is similar to Kerosene. The cloud/pour point of #1 is much lower. For that reason some stations up north mix #1 and #2 during the winter months. #1 has less energy per gallon and will reduce your fuel mileage over using #2. With the way electronic engines recirculate fuel back to the tank and keep it warm, most places rely on the additive package provided from the fuel companies to avoid gelled fuel. You have to be in some pretty cold temperatures before you need to worry about mixing #1 in your tank.
Originally Posted by Guardrail
(Post 2267602)
#1 diesel is Kerosene.
(Post 2267602)
(Post 2267602)
#1 is a little more refined than #2, but less refined than kero.
thanks a lot guys that helps me understand
