vp44 and fuel add's
vp44 and fuel add's
ok so my vp44 went out and the fricken core is bad so i am now running a vp44 that has been up'ed to run the new low sulf diesel and i have been running diesel clean but i was told that i should run atf and i was just woundering what you run your self.
OOOOOOoooooold School Mechanics used to say "Use ATF in yer Diesel Fuel".
Things were a lot different back then.
AFT now has lots of additives to prevent burn-off, and prevent clutch discs slipping.
NOT what you would want to add to your engine or fuel system to make parts slippery or keep your combustion chambers clean.
There are many, many diesel fuel additives on the market designed to burn, and to make parts move when they're supposed to move.
ronnymcdonny
Aug 15, 2007 08:44 AM
dodgemaniac
Jun 12, 2007 08:21 AM
