So...WMO question?
So...WMO question?
with people adding WMO to their tanks, is this waste diesel oil, or any oil from a gasser? will a gasser work since it's different types of oils?
and also what kind of store can I get cheesecloth from?
Not really sure what you are after here. I would think any oil will work, but all of it would be illegal. Cheese cloth is available at my local grocery store.
Keep in mind -- "black fuel" and "Red fuel" can net you the same amount in fines. If you are burning something that you aren't paying road-use taxes on and get caught, it gets expensive. If you want to burn used oil (whether fryer or motor) then you should keep track of the amount in gallons, and pay the road-use tax directly to the state to stay legal. If you make your own biodiesel, same thing unless ALL miles are offroad and exempt.
sorry buddy, but not true. they cannot bust you for using home made bio diesel or waste veggie oil. that have not yet taxed that.
they are only nailing folks for using OFF road diesel in ON road vehicles.
They have in Iowa City, IA after an idiot went on a radio program and the newspaper to brag about how much he was saving in his Rabbit. If you buy it for fuel at a station, it is taxed. If you make your own and you don't pay and they catch you, you are fined and audited.
Are you talking about the couple in IL?? Some couple got busted a couple of month back. HHMMMMM.....Lets see here. Ah here it is:
http://www.herald-review.com/article...ews/1021491.txt
This is bogus! Better not get this started going in the political arena!
Jon
Jon
In order to make it fair it will have to be based on miles travelled on public roads, not gallons. Electric cars should have to pay the same as any run on WVO or homemade BD. If the government supports alternative fuels, as they should, road taxes shouldn't apply in order to encourage widespread use.
in GA they only look for offroad diesel. In all my years, I have never seen a traffic stop to check diesel, but I don't know about the waypoints. They might check it there. Ga is pretty lax about the fuel here.
My intent wasn't to get the subject political -- I just want people to be aware there are possible negative consequences to very good ideas. I have read about truckers getting hit with dip-checks, being fined for "black fuel" just like I have read "red fuel." Didn't Peterbuilt have an automatic oil replacing system on some rigs for awhile, that would burn used motor oil at a certain rate, replacing the amount in the crankcase with fresh oil?
But that would make too much sense. I work for a company that sells propane. We run diesel powered trucks because propane for road use is taxed by the gallon even though a gallon takes you about 1/3 as far. To be fair it should be taxed on BTU value, not by volume.
