newbie to the wmo
newbie to the wmo
I have the hook up on waste motor oil, gear oil, transmission fluid. I have a few concerns. Im pretty sure there is some antifreeze in some of it, is there a filter that will filter it out? And there are a bunch of diiferent types of oils like 5w30, 15w40, synthetics, synthetic blends will these cause problems? I plan on running this in a 91 12 valve cummins and an 88 ford 7.3 idi.
thanks
thanks
Best thing to do if it does contain water/antifreeze is to use a centrifugal filter from Dieselcraft. The OC20 with pump isn't cheap though.
http://www.fryer-to-fuel.com/store/product122.html
MikeyB
MikeyB
if you have more time than money, you could let the antifreeze settle out and just suck out about a foot above the bottom of the tank. the antifreeze settles pretty quick in warm weather.
this is from experience, by the way
but DO NOT run 75% at 25* F...
PADuallyBoy
28
Jan 28, 2009 04:44 PM
