new to the WVO
what if i used 50% WVO and 50% reg pump diesel this should help on fuel prices. ive already got detailed plans for a WVO cleaner i just need to figure out how to get the water out yet and easy suggestion would help thanks in advance Ben
You will find answers to all your questions here http://www.frybrid.com/forum/index.php
Ken Gardner
Ken Gardner
Ive had good luck with an appleseed reactor, pumping dry air through hot oil via the port used for the mehtanol at the bottom. I recovered a glass of water from 55gal of 'dry' biodiesel. WVO is a little more difficult but still possible.
You want to heat that oil with a kit before it goes into your IP. Do some reading also on greasecar.com. We are in the process of installing a greasecar kit on our 93 1 ton. Your also going to need a flat plate heat exchanger. We used a 30 plate.
If you don't want to convert your truck, you need to convert your WVO into biodiesel and an Appleseed processor is what your looking at getting.
I run heated pickup, vormax heated filter, heated HIH lines and a flat plate heat exchanger and I still only see 150F after 30min of driving. Doesnt seem to do much more even if ive got the coolant at 180F. I suspect this is to do with the volume of fuel moving to the tank unused and I dont want to run a fuel loop for purge reasons. I might wire in some electrical heat on the injector lines. just doesnt seem hot enough to be safe.
You can get pre-made heaters from fattywagons.com I think.. or you can do the math and use nichrome wire and some high heat insulating tape like fiberglass, silicone or kapton.
high country
Mar 8, 2005 01:12 PM
