Which Bio for which Truck
I am assuming that your using the wrong term , for your truck , or mine ?
For any truck & blend , carry a spare fuel filter , the bio tends to clean out the system , plugging the filter , so having one with you , can save a tow .
As far as which blend to use , it depends what you are trying to accomplish ?
For performance , around 25-35% bio , bio has more centane , but a little less BTUs .
Less emissions across the board , more bio less .
No difference between B99 & B100 , except the blenders credit [ which you can not qualify for ] .
On the big upside , more lube for your VP pump .
As for using in the newer common rail systems , lot of info showing problems , mostly at higher blends , above 20-30% .
Bradleysram
19
May 12, 2009 08:36 AM
Patrick Campbell
Oct 12, 2004 05:39 PM
