acetone in diesel fuel=better milage ??
http://www.pureenergysystems.com/new...00069_Acetone/
The above link is to a site that gives a chemical analysis of what happens when you add a very small amount of acetone (1 to 1 1/2 ounce per 10 gals of diesel) to your fuel tank and you are supposed to get much better milage. Says it will work for gas rigs also. Any of you guys ever hear of this or have any info on if it works or not?
Administrator / Scooter Bum
Check the General Diesel section and the Fuels related forum.
There were several threads on this subject a year or so ago.
Most that tried it saw no definable change in MPG.
From your link
From your link
*A note of extreme caution: Acetone is a very powerful solvent, and extremely corrosive to rubber. In fact, when the acetone hits a rubber fuel line, or o-rings, or any other rubber part coming into contact with the acetone, it will slowly be dissolved away. With continual corrosion of the rubber, it will eventually disintegrate, leading to extensive repairs of the fuel line, and a possibly worse if it happened while driving. When it all comes down to it, realize that you are using the acetone at your own consequence.
Dont believe the acetone myth.
I have access to thousands of gallons of it at work and if it did work,then i'd be using it.
Also no MEK or tolulene or naptha and no mineral spirits they'll just thin down the fuel and do nothing for capilary attraction/dispersion.
Use two-stroke instead,it does make for better economy and its good for the pumps and the valve guides and the compression rings.
I saw a 2mpg increase with 2 stroke over non treated diesel fuel.
... however - it does smell nice, and makes the day go by a little slower!
DanTana
09-13-2004 09:27 PM
