Ramcharge equivalent
Old Feb 6, 2011 | 08:58 PM
12valve@heart's Avatar
I'm dreaming tonight while watching the Super Bowl so help me plan my project. I have several major goals that this project needs to meet:
1) Utilize my existing 1965 Chevy 2dr Suburban body (sentimental reasons)
2) Provide 4WD capabilities - no rock crawling or mudding, just need to get around in snow and mud that my D250 doesn't like
3) Fuel economy of ~30MPG
Because I'm building this for daily driving and economy instead of doing wheeling or heavy towing, I won't want much if any lift. I'm planning to use a mechanical Cummins ('89-'97) and a 5spd tranny but here's what I'm trying to decide:
- 4bt or 6bt
- What axles
- What transfer case
What do you recommend that I consider?
Old Feb 7, 2011 | 02:29 AM
Mike337's Avatar
Take a look at mine, Mad Max build:
http://ramchargercentral.com/rcs-tds...read-search-)/
Old Feb 7, 2011 | 07:39 AM
patdaly's Avatar
I doubt very much you see 30 MPG with a 6BT.
4BT should be doable with a OD/MT and reasonable gears. Don't forget, you don't need Dana 60's for light wheeling, Corporate 10 bolt up front, 14 bolt rear will be plenty with a 4BT.
Old Feb 13, 2011 | 05:31 PM
Interesting thread Mike337.
Pat, that's what I'm thinking. Skip the heavy axles and keep it as low as possible.
Old Oct 16, 2011 | 05:21 PM
Been doing a bunch of reading. Right now I need to keep the scope of the project as small as possible so I'm revising my thoughts to -
- Start with a running 4x4 Ramcharger
- Use it in gas form as a daily driver to make sure that the divetrain is solid
- Retain the stock R/C drivetrain
- Use a 4BT swap instead of the more common 6BT
I've seen several youtube videos of 4BT Ramchargers as offroad rigs but I haven't seen anyone yet report on how a 4BT is as a daily driver.
Any words of wisdom from those who have worked with the R/C?
Old Oct 17, 2011 | 08:07 AM
patdaly's Avatar
You still going to use the Suburban body?
If so, do some measuring on a standard 73-87 Chevy truck frame ( 4X4 ) the 4BT bolts in with the breadtruck stuff, only mod is removing the front crossmember.
Old Oct 17, 2011 | 08:19 AM
Nah. Wish I could right now but it needs too much bodywork and I need a new daily driver before the snow flies. That's why I'm thinking of a running Ramcharger as a platform to start with. Drive it in gas mode for the winter and gather parts and then drop in a 4BT in the spring.
You do bring up an interesting idea since I do have a '74 Chevy 3/4 ton 4x4 sitting out back.
Need to find a good source of bread/potato chip trucks.
Bowser50
19
Mar 12, 2009 09:14 PM
RonA
Sep 28, 2008 10:56 AM
ptgarcia
Jul 27, 2007 02:35 PM
Bart Timothy
Jul 6, 2005 06:19 PM
