Aurora 3000 (or equivalent) and 50 h.p. injectors?
Old Jul 26, 2007 | 06:05 PM
ptgarcia's Avatar
One of my first thoughts after buying my truck was to use mild turbo and injector upgrades and limit the use of electronics to make reliable and respectable power. I know this will cost a lot more but it is and always has been my preferred method. I will never drag race or sled pull with my truck, and I very rarely even hot rod much on the street. I will, however, be driving it to work every day, and on the weekends and vacations pull a large, heavy 5th wheel and do some CA desert off roading.
So I was thinking of picking up an Aurora 2000 or 3000 (or equivalent from other manufacturers), a set of 50 h.p. or so injectors (prefer Flux 1 injectors), and continue using my Quad Xzillaraider Std. (30-60-100 h.p. version). So what do you guys think? Is this something that will make a good setup for towing (no surging, no turbo bark, lower EGTs, etc.) while at the same time be up for some "spirited" driving around town and on the highway (minimal turbo lag, etc.)?
Old Jul 26, 2007 | 06:22 PM
t-boe's Avatar
HT-71 62SS or SPS 62. A GDP pump and call it good. The 62 SS would be good for the towing aspect since it can withstand higher EGT's (according to their website).
Old Jul 26, 2007 | 07:00 PM
C Schomer's Avatar
My A2k is awesome for towing and street fun and driveability is excellent - better than stock. It has a huge turbine housing and low egt/drive pressure. Craig
Old Jul 26, 2007 | 08:48 PM
Syndicate's Avatar
pretty much same as my long term goal
DDP 70 HP injectors - Done
Quad 30 60 90 box - Done
VB - Done
TC - needed still
Turbo - needed still - will probably use a BD super B & exh manifold
Old Jul 27, 2007 | 08:34 AM
omaharam's Avatar
With just Flux 1.8s, an Aurora 3k, ATS manifold, lift pump, and cp3 my truck has really good power. I'm sure it would be fine without the cp3, but obviouisly I need it when I turn up the electronics. It would be great for towing. I haven't towed with it since the Fluxs, but will be the weekend of Aug 11th. That's likely how I'll tow - electronics off.
Old Jul 27, 2007 | 09:52 AM
cquestad's Avatar
Good plan! I would look at some sort of duration box...to throw in the mix. Electronics are not bad...lol.
Old Jul 27, 2007 | 10:33 AM
ptgarcia's Avatar
I hear ya. Just trying not to overstress a particular part or system. It'll make me feel better! And I really want to keep EGTs in check, and I think a good turbo will accomplish that.
Old Jul 27, 2007 | 10:44 AM
C Schomer's Avatar
Except that duration only boxes raise egt more than any other kind! I tow on 100hp and have a hard time getting egt over 1200. Craig
Old Jul 27, 2007 | 02:35 PM
cquestad's Avatar
Power equals fuel equals heat.
Try to make 400-500 hp on pressure alone...
pwrtripls1
Feb 6, 2009 04:01 PM
omaharam
29
Jan 1, 2007 04:15 PM
fishin fever
Mar 13, 2006 06:46 PM
jimjawz
Jul 8, 2004 05:55 PM
jimjawz
Jun 27, 2004 06:16 PM
