Ford Excursion cummins swap (HPCR & 48RE)
Old Jun 17, 2008 | 07:04 PM
  #406
Mo Smoke's Avatar
It looks like the tach is on the SCP bus network to the instrument cluster and the crank signal is on pcm pins 21+22, and the cam is on pin 85+91. It is most different than the Model Year 2000 which I have so give that a whirl. Sorry for the confision but I didn't realize the year you had.
Old Jun 18, 2008 | 04:21 AM
  #407
Fireman438's Avatar
Well, i hope I'm doing this right, but I'm moving my tach discussion to a new thread so as not to steal 5.9's thunder. Again, great job on the swap, 5.9Excursion. My new thread can be found here(hopefully): https://www.dieseltruckresource.com/...er.php?u=70481
Old Jun 18, 2008 | 04:10 PM
  #408
5.9Excursion's Avatar
Here's the new thread on the tach discussion. The link above went to your profile...
https://www.dieseltruckresource.com/...d.php?t=208527
Old Jun 24, 2008 | 03:17 PM
  #409
Fireman438's Avatar
Thanks 5.9Excursion. I'm still learning how to use the features on this forum.
Old Aug 19, 2008 | 10:50 PM
  #410
proeliator's Avatar
hey Excursion can you give more info about the valve body you are using and the stand alone controller I am working with a 48re in my silverado.
Old Aug 20, 2008 | 09:38 PM
  #411
piopol's Avatar
Mpg????????????????????????
what is your mpg now with the cummins i am considering a swap too?
Old Aug 21, 2008 | 09:37 AM
  #412
Here's a link to the valve body:
It's the first one listed... "ATS Selectshift"
http://www.atsdiesel.com/atswebsite/...odge/Valve.asp
The Controller is listed here:
http://www.atsdiesel.com/atswebsite/...e/ConStand.asp
A company called Powertrain Control Solutions makes the controller and ATS makes the valve body for the 48RE.
Here's their website:
http://www.powertraincontrolsolutions.com/
MPG before was 10-11 all the time with the V10...
MPG after is now at 16.5, however that's alot of short trips (5 miles) and running around town. It's only got 6,000 miles on it too. Once it's broke in and I swap in some F1 injectors I hope to do better...
Old Aug 21, 2008 | 12:44 PM
  #413
jtharvey's Avatar
Man, you're getting 16.5 out of it with stock injectors? That's better than my 7.3 was getting. Hopefully the Flux 2's I have will help some with mileage.
Old Sep 18, 2008 | 10:46 PM
  #414
kruisecontrol's Avatar
awesome truck n thread !! when all the little stuff is worked out , finish it with some bling!! you did a truly good job .
there is a group buy going for these badges.
Old Sep 19, 2008 | 06:17 AM
  #415
xtoyz17's Avatar
Where?!?!?!?!
Old Sep 19, 2008 | 11:39 AM
  #416
Mcmopar's Avatar
Yea, where???
Old Sep 19, 2008 | 11:57 AM
  #417
97crewcab's Avatar
x3 ???
Old Sep 19, 2008 | 12:28 PM
  #418
here is the address for the basges.
badges
Old Sep 1, 2009 | 04:39 PM
  #419
Update: one year later...
Still driving it everyday. Recently put some new pulling tires on my 01 so I put it's old tires on the Excursion. 35" BFG A/T's Looks alot better now as compared to the stock sized tires. I'll try to get some pics loaded up.
Old Sep 2, 2009 | 12:13 AM
  #420
TonyB's Avatar
How is the MPG?
How do you like the trans and controller?
Tony
