Does a flexplate really need to flex?
I am trying to design a flexplate to adapt cummins to 4l80e. I have found this adapter set in a couple of places:
http://www.transmissioncenter.org/cu...bt_adapter.htm
There are also the billet flexplates like this:
http://www.xtremediesel.com/atsdiese...teupgrade.aspx
Do these plates actually flex?
If I use a standard flywheel and drill it so that it is perfectly centered will it actually need to flex?
I will be doing a couple of minor tweaks to the pump (93 ve) to improve overall fuel economy, but in my (somewhat limited) understanding, this seems like it would work.
Any and all advice, criticism, and suggestions are welcome.
Thanks, Jason
Thanks, Jason
Location: Smith Valley, NV (sometimes Redwood City, CA)
I'm a bit concerned about putting a billet one in mine. The alignment is, I think, the main issue A flex plate can allow a bit of misalignment and still not stress the crank or tranny shafts. Not an off angle of the cases so much as off center spline or a spline not perfectly straight.
I once saw a broken crankshaft that was traced to a rigid "flex" plate.
Flexplates let the converter deflect. The crank moved front to back (thrust bearing) and the flex late absorbs shock between the crank movement and the mass of the converter.
If there is a mis-alignment, the flex plate will crack.
sqrl$$
05-21-2011 11:15 AM
Spooler
33
10-15-2008 04:47 PM
hilclmr2
31
06-03-2007 03:20 PM
