Cummins Ramcharger
Old Jun 17, 2008 | 06:00 PM
  #46
farmer0_1's Avatar
with you doing all this trailbreaking and letting us in on the fixes along the way it should make my swap go way easy. still going to break away for a little road trip down your way.
Old Jun 18, 2008 | 01:06 AM
  #47
Trooperthorn's Avatar
Originally Posted by Alwaysworking
Thanks. I'm glad we cancelled the drum roll.
Old Jun 18, 2008 | 01:08 AM
  #48
Alwaysworking's Avatar
alwaysonDTR
that was a good one, i bet if it could have made a rotation it would have started.
Old Jun 18, 2008 | 01:17 AM
  #49
I found out about this rust when I sucked a couple of inches of silt out of the cowel area. There are more extensive pics on my blog. This is a shot of the inside with the dash removed, above the fuel petal.
I am almost done cutting the rust out. Tomorrow I will cut similar pieces out of a partial cab from one of my donors. Getting behind the column support/brake pedal hanger is the tricky part.
This shot is in the cowel looking behind the culumn/pedal box.
Old Jun 19, 2008 | 01:51 AM
  #50
I got the rest of the rust out today and fashioned a patch panel out of what was left of my other cab. It is not welded yet in the pic, but I do have it welded about half way now. I will finish it up tomorrow and get some POR 15on it.
Old Jun 19, 2008 | 01:58 AM
  #51
alwaysonDTR
if you remove the paint first it welds better
Old Jun 19, 2008 | 11:54 AM
  #52
Yeah, I did that, I just was not thorough in some of the hard to reach areas.
Old Jun 19, 2008 | 02:25 PM
  #53
farmer0_1's Avatar
nice patch , won't even see it after some paint work.
Old Jun 19, 2008 | 09:48 PM
  #54
alwaysonDTR
thinking about it, you should have just put the whole firewall in out of the red cab in.
Old Jun 19, 2008 | 11:33 PM
  #55
I thought about cutting it out big and overlapping it and spot-welding it in place, then goop the whole mess up with body pucky, but I thought this would be good general body patch practice. The fact that nobody will see it ia an added bonus.
Its a toss-up. The red firewall was crumpled a bit on the pass. side. I would have had to flatten it. Then, when I was done, I would have to rely on my meager welding skills because it would have been structural rather than merely waterproof.
Old Jun 24, 2008 | 01:32 AM
  #56
Updated the ramcharger blog. www.cumminsramchrger.blogspot.com
Ditched the patch job and went for the whole firewally enchilada.
The donor
Almost ready to weld.
Old Jun 24, 2008 | 01:36 AM
  #57
alwaysonDTR
still have to sand off the paint but other than that and about your nose i think you need to pull it all apart so you can fit your intercooler
Old Jun 24, 2008 | 01:59 AM
  #58
Yeah the nose is mostly apart now, just need to pull the core and inner fenders. Here is a pic of the sad looking donor.
Old Jun 24, 2008 | 09:24 AM
  #59
farmer0_1's Avatar
here i thought making a couple of cowl crack replacement panels were going to be a pain. wow. after i get my hay up i going to come down that way to survey the carnage. just think how nice it will be to have a solid ride, instead of something with rust issues. keep your chin up and don't loose confidence your doing the right thing.
Old Jul 7, 2008 | 02:10 AM
  #60
update
Lots done on this thing lately. Got the new firewall in.
Installed the heater box.
Installet the core support, radiator, intercooler, and tranny cooler. If you want to see how all this was done with an non-intercooled non-ctd core support, check out the blog in my sig. Lots of pictures and measurements.
Got the dash mostly in.
Steering hook-up is complete.
This was another head scratcher, but if you are doing the newer column and the older steering box, I have it figured out in the blog.
Getting closer all the time. Hope to drive it while it is still sunny.
