cummins to a 545RFE?
Just curious of a few things on a 2005 3rd gen 1500. thinking of dumping the 4.7L ( hold your comments about them) will the 5 speed automatic 545RFE?? currently in the truck bolt to a 6BT/4BT? electronic controls??
Thanx , crossy
Thanx , crossy
No, you can pick a fully dressed 545 with converter installed easily off the ground. Light duty. never mind the wrong converter stall speed, adaptor plate, flex plate, lack of aftermarket support etc..
I believe it would bolt using a 727 adaptor, but the 545RFE is the weak link with a hemi and no way would it stand up for a diesel. Plus there are no stand alone controllers available for the trans. I'd us a A518 or 727 which can be used without a TCM.
ProjectM880
Dec 1, 2004 06:40 PM
