B3.3T Jeep YJ
Old Nov 19, 2010 | 02:13 PM
  #1021
TonyB's Avatar
Originally Posted by CamTom12
This will make my swap SO much easier!
You will also want to look over www.4btswaps.com They not only have 4bt's, but just about any other diesel engine.
Tony
Old Nov 19, 2010 | 04:07 PM
  #1022
CamTom12's Avatar
I'll check that out too, thanks!
Old Nov 27, 2010 | 01:15 PM
  #1023
Matt S's Avatar
Originally Posted by Hulkgreen
Air to Water Intercooler is complete !!
Where did you find the air to water intercooler?
Old Nov 27, 2010 | 02:50 PM
  #1024
Hulkgreen's Avatar
This link should take you straight to the page !! I found it at Silicone_Intakes dot com !! You have the option of 4 different IC's and 3 different radiators as well as a remote reservoir, remote fill cap, and I would recommend the installation kit which is also optional !! I really like the kit and would recommend it to everyone; it is straight forward and was not difficult to install !!
http://www.siliconeintakes.com/produ...d28fea3c7b2ae2
Good Luck and let me know if you need help !!
Old Dec 13, 2010 | 06:15 PM
  #1025
farmer68's Avatar
@hulkgreen
Do you have a list of the all parts you have used in your 4.5 jeep project? I am considering your route. If you have a build forum like this one can you post the link?
Thanks!
Old Dec 14, 2010 | 10:00 AM
  #1026
Hulkgreen's Avatar
Unfortunately, I did not make a compilation list !! I have kept everything in my head, I have kind of a photographic memory !! If you ask specifically how did you do " this ", what I used or where I got it; I can tell you !!
I have been posting some over on 4btswaps but mostly here !! I use the same username over there !!
Originally Posted by farmer68
@hulkgreen
Thanks!
Old Dec 18, 2010 | 08:24 PM
  #1027
MattK's Avatar
Vg ?
TDIwyse , I was wondering if you've got a verdict on how well the vortex generators are working ? Thanks for the great post's as well ! This is probably one of the most beneficial threads on Diesel swaps in general i've read by far !!!
Old Dec 19, 2010 | 05:37 PM
  #1028
TDIwyse's Avatar
Thanks.
On the YJ I was able to quantify a measurable improvement. I also tried VG's on our Liberty CRD but could not convince myself if there was an improvement above the "noise" of normal mpg variations.
Old Dec 19, 2010 | 05:57 PM
  #1029
MattK's Avatar
Very nice ! Thank you !
Old Dec 21, 2010 | 10:54 PM
  #1030
NE frmhnd's Avatar
The 3.9 and 5.9 were designed to be industrial motors. Using them in an automotive application was an afterthought.
The first-gen Cummins uses a rotary pump, too. Up til Case went with the Fiat version of the B series, they all ran rotary pumps.
Old Dec 22, 2010 | 07:16 AM
  #1031
red_smoke's Avatar
huh? 3.3 not 4bt!
Old Dec 22, 2010 | 07:32 AM
  #1032
Kriesel's Avatar
Originally Posted by red_smoke
huh? 3.3 not 4bt!
The 3.3 is a B series, but it's a whole different animal completely. It's a Komatsu (or some japanese name starting with a K, I always get confused) design, Cummins bought it out, changed it to a B-series.
Same thing happened with the diesel in my Jeep. I have an Onan L-series, which is now labeled as a Cummins A-series, due to Cummins buying out Onan's rights to the engine, and eventually buying Onan outright.
Old Dec 27, 2010 | 12:40 AM
  #1033
Hulkgreen's Avatar
The cold weather got me thinkin about an engine block heater ( I know most of you have already adapted one into your engine ) BUT, for anyone who has not; I will post a link to a site I came across in the unGODly amount of hours I spent searching ; they are called HotStart !! The pricing I found was from the Houston, Tx. distributors website !!
http://www.hotstart.com
The following info is for In-Block heaters; but they also make other styles !!
And here is the info for the B 3.3
Engine Make : CUMMINS
Engine Model : B 3.3
Primary Part Number (120V) : FP531-004
Primary Part Number (240V) : FP532-004
Primary Wattage : 530
Optional Part Number(s) (120V) :
Optional Part Number(s) (240V) :
Optional Wattage(s) :
Port Size : 39.85 MM CORE PLUG
Heat Shield :
Installation : REPLACE CORE PLUG LOCATED AT THE LEFT REAR OF ENGINE
I could only find pricing on part # FP531-001 so the price could be incorrect :::FP531-001
In-Block Heaters are complete w/ground 6ft HPN cord and Plug.
Kim Hotstart Kim-Glo 530W 120V Direct Immersion1.978 dia
Kim Hotstart’s line of In-Block heaters mount directly into the water jacket of the engine. These direct immersion block heaters reduce engine wear due to cold starts by up to 50 percent. Warming the engine to the proper temperature also reduces idling and cranking time, saving fuel and increasing battery life.
SKU FP531001
Weight 2.0 lb
$$ 84.17
And here is the ISB / QSB
Engine Model : ISB / QSB
Primary Part Number (120V) : TF751-002
Primary Part Number (240V) : TF752-002
Primary Wattage : 750
Optional Part Number(s) (120V) : DD8L-101
Optional Part Number(s) (240V) : DD8L-102
Optional Wattage(s) : 1000
Port Size : .75" NPT
Heat Shield :
Installation : REPLACES .75" NPT PLUG IN THE FRONT OF THE OIL COOLER CASTING
TF751-002
Kim Hotstart Kim-Glo 750W 120V Direct Immersion.75 NPT THD FIXED
SKU TF751002
Weight 2.0 lb
$$ 73.91
Old Dec 31, 2010 | 07:53 PM
  #1034
Hulkgreen's Avatar
Well, here is the moment I have been anticipating since last March !! I got the exhaust finished up at Midas and I used aWalker Dynomax 2 3/4 mandrel bent 90 from Summit racing !
Without making you wait any longer; I got to drive my Cummins QSB 4.5L JEEP today !! OOOOHHHH what a blast !!! Here are a couple videos !!
http://www.flickr.com/photos/42246689@N06/5310373163/
http://www.flickr.com/photos/42246689@N06/5310373155/
Drivers Side of engine.....Completed !!
http://www.flickr.com/photos/42246689@N06/5310373173/
Passengers Side of engine........ Completed !! I still have to run the ECM wiring harness thru the firewall and run the wires to toggle switches for " Boost Power " and " Cruise Control " but these amenities can wait !!
http://www.flickr.com/photos/42246689@N06/5310976554/
Old Jan 1, 2011 | 09:35 AM
  #1035
TDIwyse's Avatar
Congrats!
