Hard time starting
Hard time starting
My 95 12 valve has been having issues to where it will only start with some pressure on the pedal after starting runs amazing has a FASS system any ideas please and thank you
Hard Starting
I have an early 98 12 valve that does the same thing with the idle set at 750. If I turn up the idle it starts without the pedal. Does not bother me since it starts instantly.
nothingbutdarts (09-24-2021)
If you read the starting instructions from Dodge on the '94-'98.0 12V trucks with the P-pump, they tell you to push the pedal in a little bit when starting them.
As the trucks get older and more miles on them the low idle throttle stop wears in and the idle slowly drops. I own a few P-pumped 12V trucks will not start without some throttle input.
nothingbutdarts (10-05-2021)
ii caan
04-14-2006 04:58 AM
Diesel-Dan
21
04-06-2004 02:04 AM
