Uni Mog??
Old Nov 22, 2007 | 07:16 PM
southpawslingr1's Avatar
Uni Mog??
At my local county pull there were several classes both gas and diesel. I dont think anyone was running close to the HP that most guys run here but no one came close to a full pull. Then for EDIT and giggles this guy pulls up in a uni mog hooks up and pulls the sled right out of the arena at like 3mph...never so much as spun a tire! What was the giagantic advantage the mog had over the other vehicles?
Old Nov 22, 2007 | 07:19 PM
scottsjeeprolet's Avatar
Portal axles, super low gearing. Those things are very tough.
Old Nov 22, 2007 | 07:44 PM
I dont understand how I couldnt just creep down the track in low range 1st gear and just keep going...the thing never ran outta traction. I know it doesnt have a heck of alot of power...
Old Nov 22, 2007 | 08:26 PM
pind's Avatar
its the super low gear ratio. I have worked on some with 658:1 ratios in low range. those things will pull, climb, descend, or push over anything that you can put in their way.
Planetary wheel end assemblies, torque multiplication like you have never seen. I have seen many of these units used in some truly ugly situations, and as mentioned above, they just don't stop.
If you can afford the purchase price, they are probably the best all around utility vehicle that you can get. There is a fellow here that uses his to pull a schulte brushcutter, all kinds of off-angle approaches and departures, lots of sidehilling, and it goes, and goes, and goes.
Old Nov 22, 2007 | 09:39 PM
JDGnut's Avatar
Weight, hitch hieght...
Old Nov 22, 2007 | 10:10 PM
fordkiller43's Avatar
Just lots of TORQUE with reeeeallly low gearin!
Old Nov 22, 2007 | 11:50 PM
displacedtexan's Avatar
His gears are WAY lower than you would be in first low. Top speed of some of em is under 60.
Old Nov 22, 2007 | 11:59 PM
SuckFumes1984's Avatar
That MOG prolly weighs 3 times what our trucks do and it has gears lower than my farm tractor!!
Old Nov 23, 2007 | 12:38 AM
westcoaster's Avatar
speaking of cool european heavy trucks...
http://www.youtube.com/watch?v=mq5mMVd3p1E
If you do a google video search on tatra truck trials you get all sorts of belching black smoke and turbo's whistling....
Old Nov 23, 2007 | 11:18 AM
BLUEBURNER's Avatar
I have a buddy that has a set of 404's in his rock buggy, they have a final drive of 7.56:1 and with a 42" tire at 3 psi have 23" of clearance at the center of the diff. The only weakness they have is snapping the portal box off if you hit it just right.
Ryan
Hintz's Avatar
they actually have good size diesels in them to (well some do)
Old Nov 23, 2007 | 11:28 AM
BLUEBURNER's Avatar
Mostly they are very small displacement 4 cyl Merc. diesels. nothing over 100hp
Old Nov 24, 2007 | 05:38 PM
Wicked K5's Avatar
Strange. There was also a Unimog at our local pulls this year. Only this guy didn't do so well. I figure he went about 175 feet and my near stock truck went 208. Wrong gear choice, inexperience, I don't know. On a side note, I weighed in right after him and asked the staff what it weighed. They told me 15,900 lbs
Old Nov 25, 2007 | 07:57 AM
Hintz's Avatar
actually no the newer ones run a, Mercedes-Benz MBE900, 6 cylinder, 260 hp
Old Nov 25, 2007 | 08:00 AM
BLUEBURNER's Avatar
Your right, I apologize, I was refering to the 404s, 406s, and 416s that everyone does the axle swaps out of.
