turbo question
Old Feb 8, 2008 | 01:00 PM
1997-12v's Avatar
turbo question
I have a 97 dodge with twin turbos on it, and i need to drop down to a single turbo to be able to run in the street diesel class. I have a turbo off of a 8.3L cummins and i was wondering how this turbo would preform any input on this?
Old Feb 8, 2008 | 03:32 PM
stock600's Avatar
I would think that would be a HX 40 and they could make good power in my opinion but i hear the shafts are weak and prone to breaking. Maybe someone else will help also....
Old Feb 8, 2008 | 06:01 PM
afoulk's Avatar
I think they used quite a few different turbine housing sizes too.
Old Feb 8, 2008 | 10:21 PM
PourinDiesel's Avatar
Not very well.
Old Feb 8, 2008 | 10:48 PM
97' CTD's Avatar
Put a S300 variant, what are the rules 2.6 if so go with a 66 inducer.
Brandon
Old Feb 10, 2008 | 09:12 PM
1997-12v's Avatar
There are no turbo size rules in the places that i pull as long as you have a single turbocharger. The bottom turbo i already have is an S-400. I just dont know if it will spool up if i were to get a different exhaust housing and run just the S-400.
Old Feb 11, 2008 | 08:35 AM
haloman's Avatar
Just run the s-400 as a single if you have enough fuel
Old Feb 11, 2008 | 09:32 AM
logskidder's Avatar
What kind of fuel would it take to a s400 as a single??
Old Feb 11, 2008 | 09:34 AM
haloman's Avatar
Umm alot. . At least a 13mm pump and matching injectors and it wouldn't be very streetable if at all.
Old Feb 11, 2008 | 12:02 PM
JDGnut's Avatar
You can spool it with a 12mm pump.. but you might not if it has a large exhaust housing.. Many of the 2.8 pullers are running something in the S400, HT60, HX60 range.. If it was used as a big charger on twins, it probably has a larger exhaust housing.. See if you can find a smaller housing..
Old Feb 12, 2008 | 05:02 AM
97' CTD's Avatar
I run a small S465 as a single with a 12MM pump .
Brandon
Old Feb 12, 2008 | 10:03 AM
dodgeboy2008's Avatar
u can get a 16 housing for it
Old Feb 12, 2008 | 01:33 PM
1997-12v's Avatar
Thanks alot for your help guys!
Ada381
Feb 10, 2008 07:58 AM
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
