tug o wars
tug o wars
i got a 97 dodge ram 2500 cummins diesel and have never entered it in a tug o war and i have no idea of what im doin, so whats the basics of winning a tug o war and how?
The key is traction. Applie your power slowly don't just tromp it and it you can get some wieght in the back of your bed to help with traction. Get something like a d-ring or a clevice to hook to your reese hitch. I've seen recever ***** snap off before while "hooking" and it is not a pretty site to see the ball go flying through the rear window of the other truck. Just beware that tis can be hard on your truck (especially if stock driveline) so be carefull.
I've done it in mud before.
400whp, BALD stock michelins (killed at the burnout contest that I won) vs 70's chevy 1500 w/ built 351 on 35x14" tires in the mud. He lost his rear axle yolk, which broke his front driveshaft, which broke his flexplate.
ok well do i let him pullme back til he starts spinnin or right after the straps tight and i start gettin pulled back? and where do i tie the strap to?
When we both started about the same time, we both just spun. When I held my brakes, he spun, then I could drag him. (By the way, the strap was a 3"X20' tow strap, so no one had an advange with weight pulling down or disadvantage with the truck being lifted up!) My truck weighs about 400# more then his. (That was last summer when we were traveling, we had them both weighed at a certified Cat scale.) It`s all about traction, and I had more then him.
Originally Posted by LanceD
buy a 4x8 sheet of 1 inch steel plate and put it under a rubber bed mat in your bed, probably a good 1500 pounds or so, I have no idea what steel weighs.
Spend a grand or more just to have bragging rights!
Mopar Jim
29
Feb 28, 2004 06:39 AM
