which trans builder should I trust?
Old Jul 6, 2005 | 09:51 PM
bmoeller's Avatar
Originally posted by GO 4LO
Tried getting info from all the major trans builders, and Dave Goerend was the only one who took the time to get back with me, and on his own time at that. I'm going with Goerend on my '93...
Chris
Talked to Dave for a couple of hours, before I bought mine. He was at home, too. Could hear the kids messing with piano in the background. LOL
For racing, I think you will need to spend more than $4k. The billet shafts are exensive. I think $4k will get you a Goerend tranny with the billet input shaft included. No other billet, though. I should've went ahead and had him install billet in mine, but didn't have the $$ for it at the time, and the tranny wasn't gonna allow me to wait. Slipping bad, even empty.
I don't think a 40/35 hybrid will be enough turbo. I can make plenty of heat with the PDR HX-40, and the 191s aren't in yet. Still sitting in the box, waiting for a socket.
Old Jul 15, 2005 | 11:54 AM
mcoleman's Avatar
Haven't heard of anyone breaking shafts on a shift. Most if not all shaft breakage is done on the launch. I wouldn't even think of racing a truck and throwing a hard launch on it without a billet input and output shaft regardless of who built the tranny. The intermediate is a pretty hefty piece and will handle normal 20 -25 psi launches. My stock output broke on an easy 10 psi launch. I've went as quick as a 1.66 60 foot time on the billet output.
Old Jul 16, 2005 | 08:19 PM
1dslram's Avatar
I broke the imput shaft on the 2-3 shift, at the Truckin for kids meet in Lancaster, CA 2 years ago, this was after a local shop modified the valve body. I replaced the valve body with a new ATS unit and a HD imput shaft installed. Then the flexplate let go, I had a SFI certified flex plate installed, after that I lunched the hardened imput, convertor and front drum. ATS covered it all under warranty with a small deductable for the $3,000.00 in parts. ATS and Bellflower transmission have been more than fair with me when upgrading or replacing broken parts that were no fault of theirs.
Bruce
Old Jul 24, 2005 | 02:05 PM
justinp20012500's Avatar
I broke an input shaft on a 1-2 shift with the TC engaged after the shift.
You break output shafts doing stall tests or high boost launches at the track.
I would much rather break an output then an input hands down!!!! Much easier to change. When the input goes it usually takes out the pump and possibly the TC.
Justin
hotdram
Nov 24, 2008 04:04 PM
JohnX
13
May 10, 2008 09:06 PM
choppers555
Oct 10, 2007 07:55 PM
nfsommer
Jan 3, 2007 02:06 PM
dukeboys
Jan 12, 2004 09:26 PM
