More then just a Yoke at Scheids
Old Aug 31, 2007 | 01:23 PM
torquet's Avatar
call Van Haisley, there is some sort of tab or something you weld/bolt onto the housing that keeps alil pressure on the ring so it won't flex under high load. I don't know exactly how it works/connects to the housing but heard him talking about it at scheids.
Old Aug 31, 2007 | 09:16 PM
Bean's Avatar
Originally Posted by PourinDiesel
Put OEM gears in it.
Yukon is basically junk.
I am thinking the same but the ARB has me messed up cause I have to have thick gears for it. It was setup right, I spent hours making sure it was shimmed right, wear pattern was perfect and backlash was dead on. Looks like the pinion went first then took out the ring as you can see the ring is broken with a pattern. Not sure what to do if the next set doesnt hold up.
Diesel-Dan
20
Sep 22, 2019 09:34 PM
robinlh
Aug 5, 2008 02:21 PM
dieselcarpenter
Sep 18, 2007 06:01 PM
Igor
Nov 25, 2006 02:27 PM
guyssets
Apr 27, 2005 12:53 AM
