Ladder Bars
Old Oct 24, 2006 | 12:04 PM
  #31
Redline Ram's Avatar
Wide
F-in
Open
Old Oct 24, 2006 | 02:14 PM
  #32
RAT_03's Avatar
DTR's "Secret Agent"
Originally Posted by WUnderwood
what is WFO?
this guy
http://www.showandperformance.com/Matt/Justin.wmv
Old Oct 24, 2006 | 04:54 PM
  #33
Gypsyman's Avatar
Below are a set of full bolt on prototype 3rd gen bars. These are on my '04-1/2.
Old Oct 24, 2006 | 05:55 PM
  #34
Luken's Avatar
Those are sweet lookin
Old Oct 24, 2006 | 11:08 PM
  #35
XLR8R's Avatar
Gypsyman - great looking bars!
They don't have any length adjustability, do they?
What's the reason for a front shackle mount with bushings instead of a heim joint?
Old Oct 24, 2006 | 11:22 PM
  #36
getblown5.9's Avatar
that front mount looks weak with u-bolts over the frame. change that and they would be nice
Old Oct 24, 2006 | 11:59 PM
  #37
PourinDiesel's Avatar
Gypsyman,
For the sledpullers I would suggest heims (not a must though). I would also suggest a solid shackle up front for the sledpullers instead of the pivoting unit.
And at least a 1.5" od bar (it looks like 1.5"?)if not a 1.75" od bar.
I think they look great though. Bolt on set is a huge bonus!! Good work.
Old Oct 25, 2006 | 10:46 AM
  #38
Gypsyman's Avatar
All good input guys and greatly appreciated. We're shooting for as much functionality as possible without killing the street manners. We have beta units going out to some heavy hitters next week so we'll see how they do as they sit.
Old Oct 25, 2006 | 11:30 AM
  #39
The right kind of traction bars should make drivability better.
Old Oct 25, 2006 | 11:34 AM
  #40
JD Dearden's Avatar
My bars are 3" steel with the hole in the middle only about 1" big, I don't remember what schedule that is. My point is my bars don't effect the driveability at all.
Old Oct 25, 2006 | 12:08 PM
  #41
XLR8R's Avatar
So what are the benefits/disadvantages of shackle mounting the front of the bars versus using heim joints?
Old Oct 25, 2006 | 12:20 PM
  #42
Gypsyman's Avatar
I shackle mounted the fronts to allow rearward travel as the spring flattens under compression.
Old Oct 25, 2006 | 03:47 PM
  #43
XLR8R's Avatar
Anyone else?
Old Nov 3, 2006 | 01:03 PM
  #44
Smoking S's Avatar
What size heim joint do you guys use? What size pipe would be recommened?
Old Nov 3, 2006 | 01:49 PM
  #45
banshee's Avatar
The front heim mount on Gypsyman's bars will only see loading that is perpendicular to the frame, or parallel to the U-bolts, not forward or rearward. Basically this ladder design works as a torque arm and the idea is to prevent the axle from wrapping in the springs by keeping the front pivot of the arm from rising. As already mentioned, the shackle provides this same effect without compromising street manners by allowing the spring to compress/lengthen without binding the rear suspension. A single bar design forces the bottom of the rear axle to follow a certain arc. If not designed correctly the rear suspension will bind during high articulation.
