an idea
Old Jul 31, 2008 | 09:16 PM
Floridacracker's Avatar
an idea
i know u want to have the rear of the truck higher
so what if i took thed shocks out and put steel rods there so it can't drop
any ways it's just an idea
so what would happen
Old Jul 31, 2008 | 09:48 PM
bluechrome's Avatar
Sometimes Making the rear rigid Does not Help. If you do run the rear rigid hanging front wieghts is a must, trust me! The truck will do wheelies without wieght. and most promoters require 1"-2" of suspension travel
Old Jul 31, 2008 | 10:31 PM
dropped2500's Avatar
i dont do any sled pulling but common sense would say that, shocks are a form of give in the suspension so if you take that give away it goes onto something else that the strain need not be on, right?
Old Jul 31, 2008 | 11:05 PM
RAMRODD's Avatar
Probably rip off your shock brackets
Old Aug 1, 2008 | 12:35 AM
jwb600's Avatar
maybe safer just building blocks if you are referring to sled pulling. they seem to work pretty well from what ive seen. I have seen some guys use the big all thread as stops in the rear but cant comment on how well it works
Old Aug 1, 2008 | 01:54 AM
Diesel Doc's Avatar
You will eventually tear or bend the shock mounts. Already seen that one tried with bad results.
Old Aug 1, 2008 | 10:51 PM
i don't pull (yet) but it just ran through my mind and figured i'd ask, thanks
torq_crowe
Sep 12, 2008 06:59 PM
wap
Sep 11, 2006 12:44 PM
jrussell
Jun 14, 2006 11:04 PM
Begle1
Jul 13, 2005 04:13 PM
Begle1
Jan 26, 2004 03:03 PM
