good day went bad
Old Mar 26, 2006 | 05:59 PM
judge88's Avatar
good day went bad
well today at the track the truck ran 12.70 with a crappy 60 ft at 1.92. then all hell boke loose. the last run of the day i decide to spray a little nos and pop goes the head gasket. freakin coolent everywere. i should of oringed the head in the first place but live and learn. ill be pullin the head to get her oringed in the morning. is there a better gasket than the stock 3rd gen? i know the 2nd gens somtimes run a marine gasket. anyway goes to show if you wanna play u gotta pay.
Old Mar 26, 2006 | 06:31 PM
Cummins Freak's Avatar
well that sucks but now with a ringed head the more you can bomb right...just trying to find the silver lining
Old Mar 26, 2006 | 06:48 PM
Jfaulkner's Avatar
Muted User
as far as I know you can't o-ring with the 3rd gen gasket, you have to use the 2nd gen version and they seem to hold up with the rings and studs.
Old Mar 26, 2006 | 07:33 PM
judge88's Avatar
why cant you oring with the 3rd gen gaskets?
Old Mar 26, 2006 | 07:54 PM
Jfaulkner's Avatar
Muted User
I think it has to do with the way the gasket is made, being multi-layer or somthing. The second gen gasket is a direct replacement except for a couple of coolant passages which are easy to cut. Whoever is doing your o-ring job probably know's what you need. It's no big deal just a different part #.
Old Mar 27, 2006 | 02:46 AM
p-pumped's Avatar
the sealing area of the third gen gasket is not round, o-rings are. studs may well take care of your problem but i think i would change over to the other style with o-rings.
ted
Old Mar 27, 2006 | 03:14 AM
AK RAM's Avatar
Was your head studded?
Nice 1/4 mile numbers!
Old Mar 27, 2006 | 12:46 PM
judge88's Avatar
yep
the head was studded. its been studded since i got the twins put on 7 months ago. i thought i was done tourqueing them down but maybe they needed 1 more time. would i be safe to replace the head gasket and just keep it studded or should i try to do the oringing with the 2nd gen gasket.
Old Mar 27, 2006 | 03:19 PM
BigBlue's Avatar
You might as well o-ring while the head is off if for no other reason than piece of mind.
Old Mar 27, 2006 | 10:39 PM
p-pumped's Avatar
make sure your head is totally flat. the kind of cyl. preasure your seeing two thousands of an inch will kill ya.
ted
VikingDiesel
Aug 12, 2007 10:10 PM
65fury
25
Apr 6, 2007 08:16 AM
drew03
76
Feb 6, 2006 07:57 AM
2500TurboDodge
Apr 7, 2005 01:49 PM
Jonsey
Oct 9, 2004 04:28 PM
