Bottom turbo on Twins Question
Old Mar 27, 2006 | 04:04 PM
masonic-dodge's Avatar
I'm looking at a B2 (s400) as a bottom turbo for a set of twins I'm getting ready to make. Does anyone know what the difference between a 110A/R and a 132A/R will make in cooling and spool-up?
CRIS
Old Mar 27, 2006 | 05:22 PM
Tom_Colesanti's Avatar
A 1.10A/R housing will spool better, yet not flow/cool as well on the top end. The 1.32A/R housing will spool slower but flow/cool better on the top end.
1.10 would be a better daily driver set up.
Old Mar 27, 2006 | 05:56 PM
blowin smoke 03's Avatar
The 1.10ar and the 1.32ar are not the same turbo,so their hard to compare!!!!The 1.10 is off an 11.1 detroit and the 1.32 is off a 12.7!!!
Old Mar 27, 2006 | 06:19 PM
I'd like to find a 110A/R for my truck that has a 74 turbine wheel and a 85 comp wheel. No one I've called can tell me both the wheel sizes and the A/R, they either know one or the other.
CRIS
Old Mar 28, 2006 | 01:22 AM
joefarmer's Avatar
Get the big one, the 1.32. I've had the pleasure of running both and the EGT control with the 1.32 was insane. 1320F pulling 18k GCVW at full fuel (drag comp + mach6's). The 1.10 is good for the smaller stuff, but doesn;t seem to get job as a primary charger done as well. It get's pretty hot on a 1/4 mile run, but it's a good compliment for 115HP injectors + drag comp. The 1.32 'hits' harder when it spools than the 1.10. Your truck will feel like it's been kicked in the rear by a F-16.
brandon.
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
sammy340
Sep 22, 2005 08:30 PM
hotmopr
Feb 7, 2005 09:27 PM
