Aurora 5000 questions
Old Sep 10, 2007 | 10:26 PM
rockjeep73's Avatar
Just wondering what diameter the exhaust outlet and downpipe are on an A5K? Also, how is the downpipe attached, v-band? bolted on flange?
Thanks
Old Sep 11, 2007 | 12:17 AM
PourinDiesel's Avatar
Thanks
The Aurora 5000 uses a custom turbine housing. The rear of the turbine housing is machined flat and is drilled and tapped for and aluminum ring (flange)that is attached by 4 bolts.
The ring (flange) is setup to mate to a standard HX40
4" downpipe via V band clamp. On 3rd gens the Aluminum outlet ring from the Aurora mounts to the stock 4" turbo elbow that is supplied with 2004.5 and up turbos.
The flange is somewhat wide and I had to source a clamp to get it to work right for me.
Old Sep 11, 2007 | 12:34 AM
rockjeep73's Avatar
Thanks for the info, thats just what I needed.
DieselRV
25
Mar 6, 2007 04:06 PM
W1cked
24
Jan 29, 2007 12:00 PM
stock03
13
Sep 12, 2006 08:07 AM
casper_cobra
Apr 28, 2006 09:54 AM
Gwoody
14
Apr 2, 2005 01:53 AM
