1st hook, need some input
you dont understand you cant just run a bigger gear, do you pull with a manual? if not then let someone who has done it answer.
i figure 2nd high for the loose tracks, if i get on a really tight sticky track then go to 4th low.
im so hooked im looking for my donor truck now to start piecing together a true puller.
Man your lucky they have pulls around you! I have wanted to pull since the first time I visited this site, but they are few and far between in my area
Pulls look real good though, the 1st track ws way too dry, and the second was good. In the classifieds dodgboy59td is selling off the parts from his retired puller for CHEAP you should check it out...
there was nothing he could do at that first pull. i pulled there too and they used a 18ft long chain so the sled never loaded the truck, hell ya could have probably ran road gear and still not have loaded the motor. runnin a big gear there would have been hard on the clutch because you were dragging the weight so starting off would have been hard on it
you put up the $1800 for the new clutch and ill run a bigger gear...if i ran the wrong gear on that first pull then why did rampage, who has pulled for 2-3 years, has double my hp, and the same tranny use the same gear i did? wouldn't he know to pull a higher gear?
Eric
I take useful advice, but I don't take stupid advice from someone who has never tried it and is basically telling me they think I should do something. Especially when i know that all its going to do is destroy a clutch.
My DD will last all thru this season of pulling so long as I don't do something stupid, like run a bigger gear. But my objective here is to make it to the end of the season, not burn it up at the first pull because someone who has never pulled with a manual tells me try a bigger gear.
Please, stay out of my thread, I'll get plenty of input from those with a 5600.
The trucks that are wound up into the defueling point all the way down the track, dont win. I WILL agree that was a heck of a crappy track, and sled, and there wasnt a lot you could do about it. But in my opinion, when the track is so slick like that, you can usually run a gear up and do a little better because of the extra wheelspeed.
Eric
Eric
FYI, the truck that won at that particular pull was a 7.3 with a few minor mods, huge tires, and weighed just under 10000lbs. That truck didn't have much wheel speed at all compared to TJ, rampage or dzlfarmboy. It just had more traction, and i don't think any of the three trucks above had a chance really. They completely overpowered the track. More wheelspeed prob wouldn't have done much. Kinda like when you spin out on ice, standing on the pedal harder (i.e. more wheel speed) doesn't help a bit.
It was the crappiest track i've ever seen, by far.
Eric
Whats your deal dude? I highly doubt taking your two sentences of advice on what gear to use is going to automatically make him a professional puller, or do better on any given track, right?
I don't think it's worth getting all worked up about, is it?
Eric
