12.71 @ 106 3rd Gen Diesel Only
Old May 27, 2006 | 12:34 AM
  #31
CButler610's Avatar
There is a new unreleased/experimental tune that does indeed eliminate TQ mgmt. It is much more agressive on all settings. Enough to hurt even a modded trans I am told.
This is just an experimental tune from the engineers and given to at least some dealers. I doubt the general public will ever see this. This is what I was told by someone at Bully Dog that actually would know. Too bad.
Old May 27, 2006 | 09:51 AM
  #32
OPIE's Avatar
If the first part of your reply is true they aren't using the right transmission mods. If the second part is true the general public will see it, but it will just come from another company. I sure am glad that we have more than one company making performance electronics/software for our trucks.
Old May 27, 2006 | 10:10 AM
  #33
lit up's Avatar
By-passing the speed limiter is easy, just cut the VSS wire (the same wire that you whould splice into for the BD eliminator) and install a switch. It is dark green with a yellow tracer being pin 12 of the ABS module. You can go the BD Power website and download the manual for their eliminator for more info. Hope this helps.
Old May 29, 2006 | 06:59 PM
  #34
essgeetee's Avatar
Thumbs up
This is hot!!! Do you expect these injectors to be a suitable for a daily driver/tower? Also is this a single cab 2wd or what? rock on man!!
Old May 29, 2006 | 07:12 PM
  #35
genros's Avatar
Don M
DOn,
Great times, congrats, What truck are you running?
WHats are the mods? (if not secret of course)
is the truck a daily driver?
more more
Old May 29, 2006 | 07:59 PM
  #36
Idaho CTD's Avatar
It's my truck and yes I do run the big injectors daily. It is a little touchy running with the BDDL like I usually do but I picked up 126hp the first time I ran these injectors. Right now I should be 500+ or - daily which is a little much for what I like so I might take the BDDL off for every day driving (stock sticks and the BDDL was in the low 400's last time I dynoed it). It has a tendacy to surge on the freeway a little especially if there is any wind.
Old May 30, 2006 | 06:53 AM
  #37
genros's Avatar
what twins are you runnin? any wastegate? would you do anything differently. Are you runnin the Dons Helix 2? (sorry for so many questions)
Old May 30, 2006 | 11:12 AM
  #38
Idaho CTD's Avatar
Yes on the Helix 2. I run my own twins (stock 600 turbo over a B2) with a Tial 38mm wastegate. If I wasn't trying to see how far I could push this Stage2 cp3 I might go a little smaller on the sticks or pull the BDDL programming. Other than that no I wouldn't change a thing.
anonymous_1
13
Apr 30, 2020 04:29 PM
BRUISER
Feb 2, 2015 11:25 AM
1qckdodge
Mar 5, 2007 09:53 AM
Camotanker
May 30, 2006 02:27 PM
mattymac
20
Oct 26, 2004 06:39 AM
