Big Rigs Talk about other Cummins powered vehicles here. As a matter of fact, it doesn't even have to be Cummins, but it will be diesel! :)
need some advice on a haul truck
Old 02-23-2015, 05:42 PM
texashaybaler's Avatar
My old 06 5.9cummins just got out of the shop from being worked to death yet again and I have decided to get a larger rig. I have looked at a IH with a dt466 and a 5+2 and a freightliner with a 8.3 Cummins and a Allison auto. I pull goosenecks loaded to the gills with hay and I want to make sure I have the right truck for the buttwhipping its about to receive. I don't have a lot of knowledge in the medium duty class of trucks and need all the help I can get.
Old 02-28-2015, 07:08 PM
Dan70's Avatar
just about anything new is going to have issues. i will say something like a kw t300 is probably the easiest thing to work on.
Old 03-07-2015, 10:39 AM
NE frmhnd's Avatar
466 is a good engine. Look for one with a different transmission though. I hate the Spicer 5 speed. Coupled with the 2 speed rear end you have 3 gears you can really split, but 4hi and 5low will be so close you effectively don't have any ratio split between them. Works pretty good with a v8 but not so much with a diesel.
The 4700 and 4900 will have a lot more room inside than a 1700 or 1900.
They pretty much all use the same running gear, just get different numbers printed on the door sticker, so you have heavy components even if your GVWR isn't. You shouldn't be able to load one heavy enough with a gooseneck to hurt it. But they won't go where a pick-up will due to the increased footprint and stiffer suspension.
dodgemaniac
Competition / Pulls / OffRoad
07-31-2008 10:15 AM
bsj04
09-20-2007 08:09 AM
ryan466
08-30-2006 10:10 AM
motrapper
11-09-2005 04:36 PM
Sean S
11-20-2003 10:23 PM
Quick Reply: need some advice on a haul truck
