Steering colume bushing
Old Oct 8, 2008 | 10:20 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
I already posted this on AB...I got the bushing from David and I would say this upgrade is well worth it.Can't beleive how well my truck handles now..No more clunks in the colume and no more steering kick going over speed bumps and holes...Sure it doesn't look like much for $70 but its't worth it...
Old Oct 8, 2008 | 10:47 PM
Lil Dog's Avatar
Was the lower bearing as hard to get out as they say? I was reading that the spring clip at the bottom is a real bugger.
Old Oct 9, 2008 | 07:14 AM
JHansen's Avatar
I did it on mine as well. Couldn't really tell how much of a difference it made by itself as I replaced the steering box, intermediate shaft and it all at the same time. But I would do it again. Not so much fun to install-on a truck with 4 wheel ABS there's a lot of extra stuff in the way of the column. IIRC I cut the spring clip with a sidecutter? Been long enough now that I can't recall for sure-but I think that was the method of removal.
Jason
Old Oct 9, 2008 | 09:46 AM
I used the die grinder on the spring clip...That was the easy part... Little more work getting the plastic cup off and I didn't even get all of it...But that was ok because when I sitted the bushing it didn't come close to touching the plastic cap that I left behind....Used a screw driver on the plastic bearing and it was a bit of a pain but I finally dug it out..
Old Oct 9, 2008 | 08:14 PM
rage_blue's Avatar
Is that available for the 24 valves too? got a clunky coloum i haven't looked at yet but wouldn't mind beefing it up.
Old Oct 9, 2008 | 11:03 PM
JHansen's Avatar
Mine is an '01-worked just fine.
Old Oct 10, 2008 | 09:43 AM
Mike Holmen's Avatar
The Guru
Dave, where did you get the part from? I broke down and bought a rebuilt steering gearbox from NAPA. There almost no road feel. Its tight feeling, but I like abit more road feel. I guess next rebuild I get a better box. It was good chatting with you the other day. At least you're getting to put some miles on that sweet ride of you're.
Old Oct 10, 2008 | 11:22 AM
I ordered the bushing from here.
http://www.rocksolidramtrucksteering.com/
Old Oct 10, 2008 | 11:40 AM
The Guru
Thanks buddy, have a good weekend.
macjazzy
13
Feb 11, 2009 01:04 PM
lews930
Oct 14, 2007 10:11 AM
walexa
78
Sep 8, 2007 05:29 PM
Dieseldude4x4
13
Jun 13, 2003 07:17 AM
