update pic on the 95
Old Oct 15, 2008 | 01:41 AM
winkdemon's Avatar
she looks at better then when i first picked her up , but still need some tlc
one on left is now
Old Oct 15, 2008 | 10:16 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Its looking good...
Old Oct 15, 2008 | 11:02 AM
winkdemon's Avatar
i need to get the wheels off my 93 on it .... will look alot better
Old Oct 15, 2008 | 10:04 PM
Mike Holmen's Avatar
The Guru
Buddy, you have to tweak with the pump and change that wastegate setting. Next, the tranny after you break it. Those trucks are so strong when set-up right. A 913 pump would help but that's later on..
Old Oct 15, 2008 | 10:52 PM
winkdemon's Avatar
i want to build a trany for it before a burn that one out , i need to truck for work . so cAN be with out it
Old Oct 15, 2008 | 10:54 PM
winkdemon's Avatar
for no wi am just going to put timing up and 5inch exhaust and cold air intake , want to do body frist
Old Oct 16, 2008 | 10:56 AM
The Guru
laser cut deliver valves and a 4k gov spring. #10 plate would help. I'm not a P pump guy, but those parts seem to wake things up the truck. Tate, is our local P pump man. At least then you can get some smoke out you're exhaust tip. I would paint afterwards, after you get everything dialed in right. I like a truck that you can actually use as a work truck. Don't get me wrong, a new paint on you're rig would make for a nice rig, but I dent things up to often. I just took my rig in for a wheel alignment, so I get to see what I have done wrong on my front end rebuild.
Old Oct 16, 2008 | 12:34 PM
winkdemon's Avatar
well i maybe going to work for a hot shot service so i need thr truck to look good . or buy never and i don't want new cost to much to fix lol . and i am cheap lol ,,,, inless i want it then i buy it , long story i am weird lol.. but i need fuel mileage right now , but first things first i need gauges
Old Oct 16, 2008 | 01:55 PM
The Guru
wheel fares might cover the rust on the rear. You could also graft in a fender bottom and/or spend some green backs on a new frt fender. Look around, I bet you can find some cherry parts, on the cheap. You could even try a garage paint job. My neighbor did his on his driveway. Its not a 5 footer paint job but it look ok at 10 ft. His gun didn't spray evenly and had lots of splatter build-up. Of course you can't say that to his face, but it was a cheapo paint job. The easiest way is just to keep the truck dirty, so no one knows how many dents you got. That's what I do...
Old Oct 16, 2008 | 06:18 PM
winkdemon's Avatar
i ma just goingt o put a box on it . i think i might just buy a gasser truck and pull box and fenders and doors if better shape . the 1000 i spend on the truck will save me more in the long run doing it like that
DMS1707
23
Nov 5, 2008 12:53 PM
MnTom
Aug 25, 2004 11:19 PM
turbo thom
Jan 2, 2003 06:09 AM
Luke S
Dec 5, 2002 04:20 PM
reverend-ron
Oct 7, 2002 07:02 AM
